Hello FORDS LOVERS!!! , i recently trying to finish my 429 for my 81' f250 but i got the motor perches done and oil pan and pick up tube but i m asking if 4x4 and 2 wd use same oil pump? cuz since i got new oil pick up tube and it seem wont work that way .. and i checked the carparts.com parts # seem to come out a bit different, oil pump is the last thing i need beofre i can intsall my engine on the frame .... HELP!!! so i can get on my project! the pump i have part nmb is m84bhv-s which is what i have now for front sump oil pan but now i have rear oil sump pan and i checked carparts.com for 4wd is M84dhv so let me know if this is right part # before i order one or whatever thanks !!!!!
I looked up a 1984 f250 with a 460 and got the part no. DM-84D It is the top picture.
I looked up a 1972 Country Squire with a 429 and got the part no. DM-84. It is the bottom picture.
As you already know, the are different. I would get the pump type that matches the year rear sump pan and pickup you have. I would think the 1984 would work, but look at the pictue to make sure.
thanks i think that 84 460 will work from the pics it look like so i m gopna search for one tomrrow at auto parts stores thanks picture reallys helps and where did u find those picture to figure them out thanks
