performance options?
Old Aug 8, 2011 | 03:21 PM
mikerans's Avatar
mikerans
what are some ways to increase the performance of my truck? mpg,hp, and maybe torque?
Old Aug 8, 2011 | 03:35 PM
almonyspm1's Avatar
almonyspm1
lots of stuff. heads, intake manifold, headers/exhaust, different gears, the list goes on. depends on your budget really if youre gonna make a big difference. check out summit.com for some ideas
Old Aug 8, 2011 | 03:47 PM
mikerans's Avatar
mikerans
well i dont have a big budget. im doin stuff little ata time. but thanks ill check it out.
Old Aug 8, 2011 | 07:03 PM
strokin'_tatsch's Avatar
strokin'_tatsch
It would help to know what your truck is. F-150, 250, 350? What engine? What transmission?
Old Aug 8, 2011 | 07:16 PM
Edgethis's Avatar
Edgethis
^^what he said, can't help if we don't have a starting point for reference.
Old Aug 8, 2011 | 07:20 PM
1800joedaddy's Avatar
1800joedaddy
Not to hijack but- let's discuss a broad spectrum of ways to improve performance.
1. And most important: Diagnose and repair all mechanical defects and impedaments. If you have bad injectors, melted plugs, shorted wires, clogged air filter, crude viscosity oil, 1/2 a quart of rear diff oil, hanging breaks or warped rotors, bad bearing, Under inflated tires, mismatched gear/tire ratios, extra weight (300lbs of junk and work clothes in your tool box), poor alignment or any other of a hundred regular maintenance projects. A BUNCH of performance comes from the basic ability to PERFORM.
2. Basic upgrades: Highflow exhaust, HF/cold air cleaner, synthetic lube and oils, performance plugs coil and wires, tunes.
3. Hard upgrades: Heads, cam, intake, higher compression, added cubes.
4. Power adders: Turbo, supercharger, N02.
How realistic are 3. and 4. for DD's? I'm considering a SC for my 5.0.
Old Aug 8, 2011 | 07:40 PM
mikerans's Avatar
mikerans
its a 95 f150 4x4. 4.9l 300-i6, and c4 tranny with over drive
Old Aug 8, 2011 | 08:03 PM
Edgethis's Avatar
Edgethis
a 95 with a C4? hmm
Old Aug 8, 2011 | 08:06 PM
mikerans's Avatar
mikerans
oops..my bad. its a E40D. i was thinkin c4 because of the 4 haha. its E40D tranny. that better? haha
Old Aug 8, 2011 | 08:11 PM
6CylBill's Avatar
6CylBill
If you want more power out of it, replace that 300 with a 351.
If you aren't willing to do that, maybe look into a gear swap. Find out what gear ratio you have and post it.
What size tires do you have?
Old Aug 8, 2011 | 08:31 PM
mikerans's Avatar
mikerans
no im not really looking to do a engine swap. but the axle ratio is 3.55. and i have 29 or 30 inch tires.
Old Aug 8, 2011 | 09:57 PM
6CylBill's Avatar
6CylBill
Well short of dropping a 351 in there or replacing your 300 with a carb'd 300 horse buildup 300, you're pretty much stuck with a 145 horse Workhorse.
3.55 is a great gear ratio with the 300. 4.10's would give you more oomph around town, but hurt your top end. Just give the ole' girl a tune up.
Old Aug 9, 2011 | 01:06 PM
1800joedaddy
Forgive my ignorance but there are no hiperf upgrades for the efi I6?
Old Aug 9, 2011 | 01:31 PM
Edgethis's Avatar
Edgethis
Nope not really. Basic tune up items. Only real options are carb it or swap motors. An engine swap wouldn't be that hard.
Old Aug 9, 2011 | 01:34 PM
6CylBill's Avatar
6CylBill
If it were a carb'd 300, you would pull gobs of power out of it.. but not with the EFI 300's.
