Sponsored by: Real Truck
Turnover Ball problem
Old Aug 8, 2011 | 12:33 PM
MisterCMK's Avatar
MisterCMK
Has anybody else had issues with their turnover ball contacting the shock? I have Rancho 9000XLs on my F-250 and a turnover ball. The clamping piece that goes around the frame contacts the shock when loaded. It looks like I need to grind away some of this plate for clearance. Anyone else run into this?
Old Aug 10, 2011 | 06:38 PM
ordually's Avatar
ordually
I've got a TurnOver ball on my 05 F-350 and haven't had any issues with the frame mounting hardware of the unit portruding enough to contact the shock (assuming I'm understanding your question). I've been loaded up to GVWR with pallets of bricks and haven't had any rubbing. The plate fits flush to the frame rail and doesn't add that much thickness on my install. I don't have Rancho's though.
Old Aug 13, 2011 | 04:49 PM
MisterCMK's Avatar
MisterCMK
I will have to take a picture. I did end up taking my angle grinder to the piece to make some clearance. I talked to a friend of mine who has an 08 3/4 ton and the stock shocks and he said that his too has very little clearance.
Old Aug 14, 2011 | 06:35 PM
MisterCMK's Avatar
MisterCMK
Alright, I think I have this licked. I will post pictures after I get back this evening. I took the angle grinder to the "c" looking piece to make clearance. I also was able to get the muffler moved down using some spacers so now the exhaust has clearance. The tail pipe could even be brought back to the stock location but I think I heard it hit once on the test drive so I may have to move that back down. Not terribly impressed with B&W and their crappy powdercoating and the fact that I have to clearance this damn thing for the shocks. Oh well.
Old Aug 14, 2011 | 09:45 PM
MisterCMK's Avatar
MisterCMK
Alright, here are the pics:
This is how the hitch was hitting on the shock. My friend has an 08 with a Turnover ball and stock shocks. He said his was very close as well.
After some work with the grinder
After grinding.
Spacers I picked up from the hardware store to drop the muffler down so the tailpipe no longer contacts the hitch head.
Old Aug 14, 2011 | 10:37 PM
dchamberlain's Avatar
dchamberlain
Did they change their design or something? My B&W doesn't have that clamping strap, just the side plates that bold to the frame. And the plate looks a lot heavier on mine.
Mine was installed when I bought the truck, but I remember going through the installation instructions before I bought the truck, because I intended to have one. I don't remember seeing anything like that before.
Old Aug 14, 2011 | 10:47 PM
cartmanea's Avatar
cartmanea
I'm guessing it's not a B&W
Old Aug 14, 2011 | 10:50 PM
dchamberlain
Well... I just looked at the installation docs online for the model that fits a 99-07, and it looks like those pictures. I'm just sure that back when I was looking at them, back in '07 when I bought my truck, it didn't look like that.
Old Aug 14, 2011 | 11:18 PM
cartmanea's Avatar
cartmanea
Maybe they've changed to a more universal design. The one on my dad's '03 looks nothing like that.
Old Aug 14, 2011 | 11:38 PM
MisterCMK's Avatar
MisterCMK
Mine is a B&W Turnover ball. I believe that they did change the design.
Old Aug 15, 2011 | 01:36 AM
TexasRebel's Avatar
TexasRebel
Did you make sure it was an 1108?
It should have come with spacers for the exhaust as well as a bracket so you can drop the pipe exit about an inch.
My 2008 has plenty of clearance all around. The only issue is the ball contacting the differential housing when the ball is inverted and i have a full load.
http://www.turnoverball.com/sites/de...04_19_2011.pdf
Old Aug 15, 2011 | 08:25 AM
dchamberlain
I think they did change it. This is in their obsolete documents section. It's for a Model 1105, which is for 99-06 trucks. This looks like what I have. I wonder if something changed on the truck in 07.
http://www.turnoverball.com/sites/de...6_obsolete.pdf
Old Aug 15, 2011 | 09:23 AM
MisterCMK's Avatar
MisterCMK
Yup, it is an 1108. There was a tailpipe bracket and the tailpipe still hit on the hitch head with the pipe spaced down. I seem to have misplaced the spacers for the exhaust so I bought some at the hardware store yesterday.
The diff housing clearance I believe is called out for the 4x2 trucks. I wonder how much different the exhaust is on the diesels versus the gas trucks and clearance.
Old Aug 15, 2011 | 09:24 AM
MisterCMK's Avatar
MisterCMK
The 2007 is the same as the 2006. I think they probably released the new model in preparation for the 2008+ trucks.
Old Aug 15, 2011 | 09:51 AM
TexasRebel's Avatar
TexasRebel
i'm not sure it's much different.
i have a gas pickup, and the exhaust would have hit the hitch body if I had not lowered it... the instructions specify diesel, but I'm thinking they never tested an F250 4x2
