No Start HOT
Old Aug 9, 2011 | 11:15 AM
BLADE35's Avatar
BLADE35
so when you say HPO always reads 500 psi when you smash the skinny pedal it should shoot up
If it stays at 500 psi at all times its not reading right
Old Aug 9, 2011 | 11:21 AM
429poweredf350's Avatar
429poweredf350
I meant it always reads around 500 when starting and idling. Skinny pedal will send it upwards of 3500
Old Aug 9, 2011 | 12:25 PM
BLADE35's Avatar
BLADE35
Im with Ya now sounds good
curious to see the ICP and IPR readings
talk to ya later
Old Aug 10, 2011 | 08:18 PM
429poweredf350
Checked ICP when hot and got .54V. When the temp drops below 140, I get .8V and the truck starts. I will p/u another plug for the IPR and do a air psi test on Sat. Sounds like the consensus is dummy plugs and standpipes.
Old Aug 10, 2011 | 08:25 PM
BLADE35's Avatar
BLADE35
sounds like your on the right track duummy plug stand pipes
Iv only heard 1 HPOP failure on 05+ and that was cause the dude thought he could go a million miles on amsoil LOL
those pumps are good ones and you already did STC fitting before
did you happen to see what IPR% was
Old Aug 10, 2011 | 08:26 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I've got nothing to add other than to say I'm glad to see it got you home from Carlisle, Jerry.
Old Aug 10, 2011 | 08:33 PM
429poweredf350
Haven't figured out how to check that yet. Will look at my AE.
Old Aug 10, 2011 | 08:34 PM
429poweredf350
Thanks Steve. Glad to hear you made it home safely as well. I'll get her fixed no worries.
Old Aug 14, 2011 | 09:57 PM
429poweredf350
Replaced the standpipes and dummy plugs. Back up and running.
Old Aug 14, 2011 | 10:07 PM
BLADE35's Avatar
BLADE35
right on Glad your back up running
was the orings worn or any cracked standpipe
Old Aug 14, 2011 | 10:11 PM
SteveBricks
FTE Emeritus
Good news Jerry
JohnnyF350
Jul 12, 2014 05:56 PM
VanDusen
Sep 21, 2010 01:54 AM
gotrope
Nov 19, 2009 12:14 PM
