SD Springs
Old Aug 8, 2011 | 10:58 AM
redman84's Avatar
redman84
SD Springs
Hey fellas. I've been out of pocket for a while but am back and have a spring question.
What all goes into installing SD springs, is it worth it, and how can I tell what code they are? Also, is V code the only desirable set? Thanks guys.
Old Aug 8, 2011 | 11:49 AM
fishmanndotcom's Avatar
fishmanndotcom
dont know if this will help you any but this is from when i swapped a set under my truck
https://www.ford-trucks.com/forums/1...ification.html
v codes (from what i read) are the most disreable bc they provide the smoothest or softest ride without giving up weight capacity.
it was worth it to me. i have only done the rear for now (front bumper was welded to the frame) but i can tell a pretty decent difference. the only thing i dont like about them is they allow the overloads to touch sooner than my old springs. i cant wait to do the front.
-cutts-
Old Aug 9, 2011 | 06:41 AM
Neal 97 250's Avatar
Neal 97 250
Yes. Rear are a breeze. I used the Sd shackles. They have larger bolts so the frame holes need to be drilled out to accept the bigger bolts. You can use the OBS shackles and not have to do that but I liked the idea of upgrading to larger bolts. Also the shackle needed to be ground down on the end that goes into the frame bracket. It is 1/4" thick and the OBS shackles are 1/8" thick so it had to be thinned a tad to drop all of the way down in there.
The front are another story. The SD springs are almost 4" longer than ours so it requires bracketry. Might as well do the Reverse shackle at the same time to improve the ride.
Sous
20
May 11, 2015 07:37 AM
Outlaw56
Mar 18, 2015 09:45 AM
chiefsk
Oct 14, 2013 07:39 PM
mgraveman
Jun 2, 2012 01:19 PM
doug51f1
Sep 12, 2007 07:50 PM
