6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Well CRAP
Old Aug 8, 2011 | 10:26 AM
rbblaylock's Avatar
rbblaylock
Well CRAP
Pull my rig this weekend, been doing it every weekend since i got the truck ni April, as usual, checked fluids before leaving
on the way to the track, coolant temp moved...alot, never got to the red, but got close, could hear the fan kick on (never heard it that loud before) temps go back down. made it no problem
Coming back, temps steady, lost power, acceleration, everything...but no engine light. Stopped at a Autozone, got a B1145, B1234, P0088 (only one that mattered) its the HPFP
we dropped the trailer, drove for awhile unhooked and ran perfect until same problem repeated itself this time with a nice check engine light.
The vid shows the rpm and turbo with consistent pedal on a flat road, no wind
‪08 sucking‬‏ - YouTube
2008 F350, 84K, no mods, updated prior to 04-2011
flat road, no trailer 100+ heat
please make my truck not suck
Old Aug 8, 2011 | 12:29 PM
powerstroke72's Avatar
powerstroke72
Moved to correct forum.
Old Aug 8, 2011 | 12:44 PM
senix's Avatar
senix
sounds like your HPFP went to lunch. Be sure you fuel filters have been changed.
Old Aug 8, 2011 | 01:32 PM
rbblaylock's Avatar
rbblaylock
they were changed 2 weeks ago. not by ford, but by a lube place locally. do i need the invoice with me?
Is there much run around with ford on this one? Im taking it in as soon as im out of work, around 4...just wanting to be prepared
Old Aug 8, 2011 | 01:45 PM
2010F350's Avatar
2010F350
Better have been ford filters..
Old Aug 8, 2011 | 01:54 PM
senix's Avatar
senix
Ford filters or don't even bother to go. Get the correct filters and see what goes from there.
Old Aug 8, 2011 | 02:06 PM
rbblaylock's Avatar
rbblaylock
just spoke to the lube place, they used Service pro.
Called the dealer and asked if other brands void the warranty, he said no. As long as its a certified mechanic doing it.
Maybe Ive got one of the "good" dealerships??
Im taking some vaseline with me...just to be safe
Old Aug 8, 2011 | 02:22 PM
senix's Avatar
senix
Good luck! lube place is not going to be a cerified mech...it is someone off the street. But now the cat is out of the bag.
Hopefully they still warranty it.
Plan on the truck being there a few days. It is a cab off for the repair if that turns out to be the issue,
Old Aug 8, 2011 | 02:40 PM
rbblaylock's Avatar
rbblaylock
this lube shop is ASE cert.
and when i called, it wasnt in connection with my service claim, i just asked a basic question. So hopefully everything checks out.
But by watching the vid, does it seem like there may be anything else going on with the motor? with rpms surging and turbo psi going down at the same time?
Most of what i read with the HPFP is it just losing power and limping. Mine would literally take off then almost shut down completely
Old Aug 8, 2011 | 04:19 PM
senix's Avatar
senix
well keep us posted.
Old Aug 8, 2011 | 04:39 PM
2010F350's Avatar
2010F350
seems like a turbo issue to me!!!guess time will tell.
Old Aug 9, 2011 | 02:23 PM
rbblaylock's Avatar
rbblaylock
UPDATE!
HPFP out, getting replaced. Didnt bother going through ford, said they have enough problems with them to know whats going on.
Found a coolant leak, nothing big, but some residue on the tank. Said the tank was cracked. Replacing for free!
TSTAT stuck on previous owner, dealer said the crack could have happened then.
last but not least, said my wipers were streaking...however they wouldnt replace those for free...... 2 out of 3 aint bad HAHA
Old Aug 10, 2011 | 08:32 AM
JcF204's Avatar
JcF204
Wow, glad to hear things will be ok for you
Old Aug 10, 2011 | 08:57 AM
Rudiak's Avatar
Rudiak
Are you saying you found someone other than Ford to do the work under warranty? What kind of warranty do you have?
Old Aug 10, 2011 | 12:27 PM
rbblaylock's Avatar
rbblaylock
ford dealer working on it, what i meant by them not going through ford was them not having to try and get the FP warrantied. Said they used to go and check them our for debris, bad fuel, what not, now (maybe just in the Houston area) they just replace them.
I have the original 100k, but the TSTAT was stuck @ 67k on previous owner. They replaced TSTAT then, no other fix. This guy is saying it "could" have damaged the radiator back then, and either now cracked, or cracked all along, which the later isnt the case, ive checked coolant in the 4 months ive had this truck.
