9" axle bearing help
Old Aug 8, 2011 | 12:24 AM
71cc's Avatar
71cc
I have a big bearing (early style) 1970 that uses a sealed roller bearing PN514003 . The issue I am having is axle endplay. Normally it wouldn't be a problem but I have converted to 77-79 Lincoln Mark V rear disc . I have about .03" endplay which causes pad knockback, noise, excessive pedal travel before pad touches... I want to convert to a tapered bearing, even a sealed one would be fine, to eliminate the endplay issues. My axle does not have the provision for a seal surface outboard of the bearing, nor does a Set A20 share the same inner diameter (1.53 vs 1.56). Any suggestions ?
Jeepers2003
May 17, 2010 05:12 PM
Bullitt390
Sep 3, 2009 11:45 AM
Mudfoot
1997 - 2003 F150
Nov 4, 2008 06:33 AM
rebocardo
Oct 5, 2004 09:11 AM
cwade3
Jan 5, 2003 07:36 PM
