transmission leak
Old Aug 7, 2011 | 11:21 PM
mwkobe's Avatar
mwkobe
transmission leak
Ok im puzzled my 2002 mm 4.0 awd likes to spew atf out of the bell housing when im cruising threw moderately hilly areas like going a cross PA on I 80 or on I 90 the mass pike it pours out like crazy you think the cars on fire then if i slow down and turn over drive off it stops on my way back thru heading the other way i left overdrive off and it didnt leak
what should i look for?
wayne
Old Aug 7, 2011 | 11:37 PM
aquanaut20's Avatar
aquanaut20
Transmission is getting hot and leaking from the front pump seal... Philip
Old Aug 8, 2011 | 08:08 AM
mwkobe's Avatar
mwkobe
so i need to add a better cooler then?
wayne
Old Aug 14, 2011 | 09:07 PM
mwkobe's Avatar
mwkobe
what would you all recommend for a cooler?
beaverplt
Escape & Escape Hybrid
Aug 28, 2017 09:08 AM
maytag906
13
Aug 12, 2014 03:37 PM
joeyoung2008
Jun 2, 2009 06:43 PM
ADMSWELDING
21
Apr 10, 2009 11:58 PM
AKCrazy
May 16, 2006 10:14 PM
