Rough idle, problem inside valve cover
Old Aug 7, 2011 | 07:51 PM
blbowers's Avatar
blbowers
My ’97 F350, 7.3 with 240K began idling very rough after a difficult start. It smelled like something burning so I checked under the hood and there was no smoke. I removed the oil cap and smoke was coming from inside the valve cover and it smelled like burned plastic. With the engine idling (very roughly) I disconnected each of the four plugs feeding into the valve covers. I’m assuming these are for the fuel injectors but I’m not sure. Disconnecting either of the two on the passenger side had no effect on the rough idling situation. Disconnecting either of the two on the driver’s side caused the motor to die.
Could anyone advise what the problem could be? Should I take it to a shop or do it myself? I am not a mechanic, but I manage to stumble through oil changes, brake jobs, water pumps, alternators, shocks, and stuff like that.
Any help is appreciated!!! Thank you!
Bigblockboy
Jun 21, 2016 03:48 PM
Brendancory1992
Oct 19, 2015 10:16 AM
mo76
Jul 31, 2014 09:30 PM
chris491
Jun 14, 2008 03:11 PM
muddyford75
Jul 27, 2005 05:27 PM
