I ordered new plungers today. No lights come on when the headlight **** is turned. Are there any online fuses or circuit breakers under the hood? I appreciate the help!
check to see if you have 12v at the overhead/dome light 1st, could be no power or no ground, wire going up the A pilar could be disconnected or broke also
'A' pilar is the post which runs from the cowl to the roof..referred to as a pilar..'B' pilar is behind you, where the shoulder belt is... and if you have a crew cab the 'C' pilar is behind that, as in 4dr cars
checking the voltage is free and it will tell you if one of the necessities..12 volts.... is there, if it is then check for a bad ground, check w/ the doors open and then the headlight switch turned/rotated to turn on the interior domelight w/ doors closed, one could be good and the other bad
youre welcome..good luck
I had a cd player installed recently and the tech told me there was a bad solenoid in line somewhere behind the deck that he was trying to tap into. Could that be the issue?
