MC removal
Old Aug 7, 2011 | 05:31 PM
Pappys53's Avatar
Pappys53
MC removal
I am removing my stock mc to rebuild it. What has someone use to remove the spring? Several attempts and I was unsuccessful.
Old Aug 7, 2011 | 06:03 PM
Doc's Avatar
Doc
I had trouble with a spring like that once and used a plastic zip tie to remove it. Get a medium sized zip tie (the one that's about an 1/8th once wide or wider). Make a big loop out of it and hook it over the end of the spring (probably on the engine side). Now you can pull on that loop or pry on it with a bar or something from a distance and it wont break your knuckles.
EDIT: Are you sure you need to remove that spring? If the push rod connected to the pedal is okay, I would just reccommend that you leave that part alone and just replace the MC. (Unless the 53 is really different from the bonus builts)
Old Aug 8, 2011 | 07:25 AM
Pappys53's Avatar
Pappys53
Been awhile since I did any work on mcs. The mc will pull off the plunger? How hard will it be to get it back on?
Old Aug 8, 2011 | 07:29 AM
Doc's Avatar
Doc
Not hard at all. Just make sure you get a new rubber boot with the new master cylinder. Again, I'm ASSUMING that the 53's have the same type setup at the 48-52's. The rod just pops through the boot and seats itself into the master cylinder.
pezsox
Sep 7, 2016 03:04 PM
kbf1961
Apr 6, 2015 07:29 PM
62dump
Jun 12, 2009 12:53 AM
Ed Wagner
Dec 13, 2004 04:22 PM
gadams
Jun 22, 2001 06:24 PM
