1978 - 1996 Big Bronco
Engine Model
Old Aug 7, 2011 | 04:23 PM
blkfordtruck's Avatar
blkfordtruck
Engine Model
Is the engine model stamped on the block somewhere? I know there is a decal under the hood but want to make sure the engine has not been swapped with something else.
Old Aug 7, 2011 | 05:06 PM
Encho's Avatar
Encho
The Southernmost Mod
No, only physical recognition, post some pictures and we'll tell you which engine you have. But a simple rule: If it's an I6, then it's the 300, if it's a V8, check for the water pump at the front, if one of the screws holding it in place seem to reach the heads, it's a 302, if it's a couple inches farther then it's a 351.
Old Aug 7, 2011 | 06:12 PM
Edgethis's Avatar
Edgethis
There is a casting number on the block. On the bottom near starter usually on the V8s. Sometimes have to pull starter off to see and wipe crud off block.
Old Aug 7, 2011 | 09:13 PM
blkfordtruck
Ok thank ya'll. I'm about to pull the engine for repairs and will look for the numbers or post pic.
77f100guy
Jan 3, 2010 05:56 PM
TheKirbyMan
Aug 12, 2009 03:41 AM
jrandalls
Aug 12, 2007 11:24 AM
ROKRAWL
1966 - 1977 Early Broncos
Nov 2, 2003 10:02 PM
