Trailer Brake controller problem
Old Aug 7, 2011 | 11:32 AM
Jx 1014's Avatar
Jx 1014
My cousin has a 06 f-250 with the 6.0 and he has the stock trailer controller.
He is not getting any lights or breaks on the trailer and we know its not the trailers because every one we have works on our V10 f-250. We tested it with a voltage tester by putting the ground clip on the ground on the plug and touching the prod to all of the prongs on the plug. The light flashed on the signal lights it stayed solid on the park lights and when the brakes were turned on the tester lit up. What is the problem??????????
Old Aug 7, 2011 | 12:00 PM
69cj's Avatar
69cj
Can't tell you which side from here but it appears that your trailer is losing it's ground. Double check the ground connections on both sides, ie: the plug and receptacle. A weak ground can read with a meter and lose continuity under load.
Old Aug 7, 2011 | 12:15 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Is this with the trailer hooking up on the hitch, or NOT resting on the truck's hitch? If NOT on the hitch, see the post above. If it is on the truck's hitch, it may STILL be the ground between the truck and trailer. It may also be a very dirty or broken wire inside the bundle of wires that connect to the trucks connector.
As far as brakes go, my '05 will NOT supply brakes to the trailer untill you are going fast enough so that the auto door locks lock. It was one of Fords more stupid ideas......
Here's a link to the 7 way plug connections:http://www.ford-trucks.com/forums/59...g-diagram.html
Old Aug 7, 2011 | 01:16 PM
RV_Tech's Avatar
RV_Tech
Since the trailer works with other trucks and you have a light at your tester on this truck, I would think you have a poor connection between truck and trailer, although I certainly agree with preceding comments regarding other possibilities. Poor connections are the overwhelming first choice when it comes to problems towing. I would suggest that a test light is of limited value in troubleshooting this type of problem as it does not provide you with enough information.
Steve
Old Aug 7, 2011 | 02:47 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Check fuse #9 in under hood power distribution box. It's for bright filiment power (turn and brake) in 7 way plug only. If it's ok, check continuity between truck and trailer as others suggested.
Important to know 7 way plug is not just tagged onto tailight wiring at the back of the truck. It has it's own fuses and relays.
Old Aug 7, 2011 | 03:48 PM
Jx 1014's Avatar
Jx 1014
thanks for the reply but the problem is I'm pretty positive it isn't the connection because the inside of the plug on the truck looks brand new
Old Aug 7, 2011 | 04:58 PM
Rusty Axlerod
Fuse# 9 was ok? How many ohms between truck and trailer frame?
Old Aug 7, 2011 | 05:26 PM
69cj's Avatar
69cj
Good question to put the lost or floating ground to bed.
Old Aug 7, 2011 | 07:11 PM
RV_Tech's Avatar
RV_Tech
Ford plugs break down on the back side where you can't see the problem. The ground pin in particular will just about rust off on the back side due to water penetration.
Steve
Last edited by RV_Tech; Aug 7, 2011 at 07:19 PM. Reason: typed can, meant can't so changed to can't
Old Aug 7, 2011 | 07:22 PM
Jx 1014's Avatar
Jx 1014
we'll have to check some things when i see him tomorrow thanks for the suggestiosugestions
Cylesdale
Apr 12, 2020 11:16 PM
old farm truck
All Things Towing
26
Sep 2, 2017 08:59 AM
greenheads
All Things Towing
22
May 25, 2015 05:36 PM
richsoucie
Aug 29, 2008 02:20 PM
Loudmouth LS1
All Things Towing
15
Jul 25, 2007 06:55 PM
