Help!
Old Aug 7, 2011 | 10:31 AM
jepps's Avatar
jepps
Help!
just installed a new fuel pump into the front tank of my 96 f250 5.8. had a cheap fuel line remover tool and couldnt get the fuel lines off. went out and picked up a good tool and lines came right off. just tried to reinstall the lines and saw i had damged the inside of the quick connect fitting that goes in above the fuel pump. the fuel line is on only about 2' long but goes into a block with the other lines so i cant remove to replace. how the heck do i get this line off. it goes into a small block along with the other lines. theres no quick connect where the line goes into the block. does this mean i have to replace all the lines and the block because of the fitting? Can I replace the braided line with rubber fuel injection hose and clamps. if so do i cut off the braided hose at the block or is there a way to remove it?
Old Aug 7, 2011 | 10:42 AM
jepps's Avatar
jepps
its a braided line. can i just replace it with a rubber fuel hose and clamps from the top of the pump to the block?
Old Aug 7, 2011 | 01:23 PM
Slip ford man's Avatar
Slip ford man
I think you can use a special rubber or nylon
RockAuto Parts Catalog
look up your year/fuel line, connectors, maybe block there too, to examine how it works
chris64
Jul 28, 2009 11:25 PM
bob_351
Jun 1, 2008 10:12 PM
gotsmoke
Apr 1, 2007 09:33 PM
kidoo
Mar 13, 2006 12:20 PM
mike L
Jul 22, 2004 03:57 PM
