Can 302 MAF be put onto a 351SD?
Old Aug 24, 2011 | 07:36 AM
Conanski's Avatar
Conanski
You want a 5.0 or 5.8 MAF computer from a '94 or '95 truck with an E4OD transmission.
Old Sep 3, 2011 | 12:31 PM
Blue Rebel's Avatar
Blue Rebel
One last question for ya... The distributor is the same between SD and MAF, correct. And would i want one with the steel gear, or cast iron gear?
Old Sep 3, 2011 | 12:58 PM
lew52's Avatar
lew52
If it has a roller cam then you need a steel gear , flat tappet cast gear....
Old Sep 5, 2011 | 08:55 PM
73FOMO's Avatar
73FOMO
Originally Posted by Conanski
Well actually that's not quite right either. There is noting about any of these engines that are SD or MAF specific, the motors are the same for both EFI systems. So the OP simply needs a complete 5.8 EFI motor from any vehicle, SD or MAF, manual or automatic trans, pickup or van.. it doesn't matter they're all the same or at least close enough that you can make any engine work with the right combinaton of parts.
I was assuming he wanted a MAF setup although he did not specify in the op. You can use a 5.0 eec although I would tune for the 351 if I used the 5.0 eec.
dozernsasha
19
Feb 12, 2016 10:36 PM
hilda
35
Jan 28, 2011 10:55 AM
hsmaverick
1978 - 1996 Big Bronco
Aug 3, 2010 04:28 PM
Dmford
Engine Swaps
24
Feb 5, 2007 06:26 PM
