95 e350 mh turn sig problems
Old Aug 6, 2011 | 10:46 PM
mewisemagic's Avatar
mewisemagic
have replaced bulbs and still can't get front right to blink at all,rear right will blink and it will make the rear park lights blink?replace the turn signal relay,didn't help . also the right turn sig. indicator lamp on dash won't work but it will work on hazzard and crusie control won't work either? could it be the turn signal switch in sterring wheel?left side lights seem to be okalso on the right turn signal,when switched on,it makes the sound but no light on dash,but if you turn on park lights the sound will stop and both filaments in the rear bulb will be lit,front still doesn't work other than the park light. checked wires in the rear where they enter and all looks good. do you think it could be in the trailer brake controler switch or headlihgt switch
Old Aug 7, 2011 | 10:31 AM
jonesg's Avatar
jonesg
My van failed inspection due to indicators, I had the mechanic fix it, the indicator switch was pricey .
Old Aug 7, 2011 | 05:15 PM
mewisemagic
it has no power at the frt.right socket with turn signal switched on,but works with hazzard and park light works
Old Aug 8, 2011 | 07:46 AM
jonesg's Avatar
jonesg
Has to be a wire issue if the right rear flashes, break in the circuit.
I'd just run a pony wire from the relay to the right front plug and be done with it.
Old Aug 8, 2011 | 09:13 AM
subford's Avatar
subford
You have a ground problem.
Anytime both filaments in any bulb come on when only one is called for there is an open ground to that bulb.
Old Aug 9, 2011 | 08:13 PM
mewisemagic
well, turns out it was a bad turn signal switch,thanks for the help everybody
muladesigns1
Jun 4, 2010 09:58 PM
oscarxyz
16
Apr 30, 2007 05:03 PM
ct.russ
Mar 5, 2006 04:49 PM
HarleySteve
Nov 11, 2005 08:39 PM
Dennis_IL
Electrical Systems/Wiring
Mar 12, 2002 06:57 PM
