Hoping someone can answer this quickly
Old Apr 1, 2003 | 02:15 PM
the law's Avatar
the law
I've got a pretty brutal oil leak from my oil pressure sensor. This is on the truck in my signature. I can't even see the thing, I can only barely touch it reaching around the back of the engine. To reach it, I have to reach through a bunch of wires and vacuum lines. The problem is, I accidental pulled a couple vacuum lines out of where they came from, and I don't know where that is.
The two lines go into some male terminals on the firewall, near the top, on the passenger side. They are aproximately 1/4" ID, 1/2" OD. There is a smaller vacuum line that goes into the firewall between them. I just need to know where these lines come from, as that is what I don't know.
Old Apr 1, 2003 | 03:02 PM
the law's Avatar
the law
Also on the subject, is the oil pressure sensor a 1-1/8" nut? My 1" socket doesn't quite fit over it.
Old Apr 1, 2003 | 07:09 PM
the law's Avatar
the law
And finally, I just got back with my new 1-1/8" socket, tried it, and it's way too big! Is there a such thing as a 1-1/16" socket?
I tried the 1" again, and I ain't smokin' crack, it's too small.
Maybe it's some sort of weird metric piece of crap. I've found metric bolts on occasion before, so I guess it is possible.
Old Apr 1, 2003 | 07:28 PM
Sportdeck262's Avatar
Sportdeck262
Yes there are 1 1/16" sockets. If it is metric, 1"=25.4mm and 1 1/8"=28.6mm, so a 26, 27 or 28mm socket could also be the potential size. Buy all four and return the ones you don't need, or buy a set of large metric and SAE sockets. It might not be much more than the cost of the 4 separate sizes. Good Luck!
Old Apr 1, 2003 | 07:29 PM
merc460's Avatar
merc460
Most senders need a 1 1/16 socket . so your are not on crack. Eric
Old Apr 2, 2003 | 08:04 AM
georgedavila's Avatar
georgedavila
Sounds like the vacuum lines would be for your heat/venilation controls.
Old Apr 2, 2003 | 09:33 PM
rednec245's Avatar
rednec245
Any auto parts store should have a socket to fit an oil pressure sender. It an oddball size and the sockets are deep, but the same socket will fit almost any oil pressure sender.
Old Apr 2, 2003 | 11:15 PM
Superdave's Avatar
Superdave
Are the sending units different on the newer 460's?
Mine has a hex nut under the round, top part of the sending unit. Its just above the threaded part where it screws into the block. I believe it is a 9/16". An end wrench gets it for me.
Old Apr 3, 2003 | 02:34 AM
the law's Avatar
the law
Yeah, it turned out to be the 1-1/16th" socket. I took the opportunity since I was back there to install an oil pressure guage, since the one on my dash is just an idiot guage.
I think I have the vacuum lines hooked up right, but when all was said and done, I had a 6 or 7 inch peice of vacuum hose laying on the frame, and I can't seem to locate where it came from. Everything else seems alright, though. In fact, I think a couple of those lines had been disconnected a while, 'cause when I put the hoses on and fired her up, she idled better and the C6 shifts firmer and at better points.
