1966 - 1977 Early Broncos
Starter???
Old Aug 6, 2011 | 01:28 PM
the Coondawg's Avatar
the Coondawg
Starter???
'77 302. Had no issues of late but took the battery out to use on an Expl. Put the battery back in and I get one click on the sol. I replaced the ground to sol wire, the sol and the starter tested good. I turn the key and I get nothing now. I've got power (the fuel pump is running) but no click. This sounds like it is the starter even though it tested good.
The starter I noticed is off a 95 cause it has the sol on the side. Just wondering what y'all thought before I go get another starter.
Old Aug 6, 2011 | 04:58 PM
the Coondawg
I replaced the starter, solenoid and ground wire all to no avail.
Old Aug 8, 2011 | 09:38 PM
Boba Fett's Avatar
Boba Fett
Battery is bad..... try jumping the battery....
Old Aug 8, 2011 | 10:39 PM
the Coondawg
Its hittin at 14 volts and pulls the fuel pump and lights with no problem. I'll try hookin it up to jumper cables
Old Aug 9, 2011 | 06:14 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Not familiar with that starter, but you need to verify that you are getting voltage from ignition swwitch to energize the solenoid when you turn key to start position.
Treay Turner
22
Oct 6, 2017 11:00 PM
cjben
Mar 16, 2016 03:54 PM
TritonF150
2004 - 2008 F150
Oct 26, 2014 08:43 PM
dracip
Jan 28, 2008 06:43 PM
ford429cu
May 6, 2002 05:43 PM
