Sponsored by: Real Truck
how do i remove my PCV valve? pics inside
Old Aug 6, 2011 | 09:45 PM
hotroddsl's Avatar
hotroddsl
It does not have the wear spot on the crossover anymore? Or the rubber elbow into the manifold? Cool beans cuz those two spots caused more f'n bank 1 too lean, bank 2 too lean codes, and a bitch to feel back there with my big paws!
Jim...& fat Monty
Old Aug 7, 2011 | 09:32 AM
dkf's Avatar
dkf
Completely different setup, no more elbow, different hose and valve.
Old Aug 7, 2011 | 09:38 AM
hotroddsl's Avatar
hotroddsl
Thank GOD THAT OLD SETUP SUCKED!
Old Aug 8, 2011 | 08:19 PM
SuperDutyScaler's Avatar
SuperDutyScaler
DKF my hose is different than yours, mine goes behind the motor and has a foam covering over it
Old Aug 8, 2011 | 08:24 PM
dkf's Avatar
dkf
Yours is a 5.4l and might be an earlier build date. Does the hose have the same connectors on both ends?
Old Aug 9, 2011 | 11:27 AM
SuperDutyScaler
no i only have one connection on top and the hose goes right back to the back of the motor.
Old Aug 9, 2011 | 11:29 AM
SuperDutyScaler
Old Aug 9, 2011 | 11:30 AM
SuperDutyScaler
see only one line with foam wraping
Old Aug 9, 2011 | 11:31 AM
SuperDutyScaler
DKF maybe the V10's have two PCV lines and my 5.4 only has one? i do know thats the right part number you gave me and they use the same PCV it looks like
Old Aug 9, 2011 | 12:05 PM
SuperDutyScaler
my dealer wants $27.50 for a new one, o and they dont have it in stock. so i have to wait till friday
dkf's Avatar
dkf
Should only be one PCV line coming off the passsenger side valve cover. My V10 only has one and there isn't a reason for two to come off the same bank. The intake is obviously different on the 5.4l. I was referring to the other end of the PCV hose where it connects to the intake. Does it have a connector like the end that connects to the pcv valve?
Old Aug 9, 2011 | 12:18 PM
SuperDutyScaler
sorry i have no idea i didnt even look back there. should i buy the hose too or is it like hard flexible line? so it should be ok? im just gonna go to the dealer right now and order one and maybe the hose too?
Old Aug 9, 2011 | 02:08 PM
  #28
dkf's Avatar
dkf
I would not order a hose. You can peel back some of the insulation and inspect it when you install the PCV valve. I would also try to inspect the hose up to the connection point on the intake just o make sure everything looks good. If the hose is bad get one. It would suck paying $75 dollars (or whatever the dealer charges) for a hose you don't need.
Ian Roach
1983 - 2012 Ranger & B-Series
Aug 10, 2019 09:51 PM
Apocalypse
Jul 27, 2019 10:44 AM
jdq
2009 - 2014 F150
Feb 27, 2017 08:53 AM
azwolfman
May 28, 2005 10:36 PM
