1985 460 Choke(?) issue
Old Aug 5, 2011 | 12:31 PM
Galm_2's Avatar
Galm_2
Hey guys, my old truck is a little hard to start spmetimes, she'll start and then about die 3-5 seconds later, sometimes on the second time it will stay running or on bad says it's the third. Once running it's fine. Of course the off idle response is sometimes sluggish and needs a quick rev to get going.
Hoping it may just be the choke and not need a carb rebuild
I also need to fix the door-interior light switch but that's pretty easy, right?
Oh, stock Holley carb.
Old Aug 5, 2011 | 01:08 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Remove the air cleaner and see what position the choke butterfly is at, then pump the gas once and see how it changes.
When you pump the gas it should set the choke, which will let the choke butterfly close the rest of the way and it will put the throttle at the fast idle position. You will notice that the little plastic fast idle cam between the choke housing and the carb goes up. You can manually push it back down to take it off the fast idle position. Pushing the throttle again will put it back at the fast idle. When you push it down you should notice the throttle close a small amount.
You also want to make sure the choke opens fully when the engine warms up.
Old Aug 5, 2011 | 01:19 PM
Galm_2's Avatar
Galm_2
Oooh, see me and my dad read the Ford manual that came with the truck to hold the throttle 1/4 to 1/2 when starting.
This would explain quite a bit, thanks!
Old Aug 11, 2011 | 04:05 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Any progress?
I pump the gas one time and it starts right up.
Old Aug 11, 2011 | 05:12 PM
Galm_2's Avatar
Galm_2
Oh, sorry yes!
Does the same as yours does. One pump and it starts.
However, now it hesitates when giving past very light throttle. Checked a few plug wires and found some loose ones, hopefully that's it. :l
Old Aug 11, 2011 | 07:25 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Yeah, hopefully that will fix it.
But if it doesn't; one of things the Mustang guys do to these carbs for off-idle hesitation is install a larger accelerator pump discharge nozzle. Stock is #28, a good replacement is #31.
alexjp91
Dec 20, 2015 10:46 AM
wotan
32
Aug 29, 2014 08:29 AM
Regg_65
Oct 29, 2008 03:38 PM
boggerted
Nov 17, 2007 03:32 PM
yellow78ford
Aug 5, 2006 02:58 PM
