New IFS Interest...
Today I ran into a dilemma and am reaching out to you for your expertise.
I am contemplating an IFS & IRS for my 56 (so much for keeping it stock but I really would like it to drive / handle like a new vehicle).
So when thinking about this, I think that when one upgrades to IFS/IRS there is a host of other things that "naturally" need or should be changed as well and instead of being blindsided by the unexpected, I am reaching out to you my friends for your experience.
So it goes like this... If I upgrade to IFS do I need to look at a new/different steering column? new different master brake cylinder? new different power steering components and there is where I get so overwhelmed that I start thinking... nah, let it be a 56 truck with 56 components...
Please please please, give me your .02 cents - or more if possible.
Paul
IRS is nice, but is not really necessary to have your truck handle like a newer vehicle. There's lots of fine handling cars, even those built today, that don't utilize IRS. It really depends on your budget and fabricating skills. If you can do it, and really want it, awesome. Go for it. But just understand you can have a fine driving and handling machine without the added expense and labor involved.
IFS is another matter. And for ease of assembly and modification, I will always recommend a MII-based kit from a quality manufacturer, like Heidts, TCI, and a few others. These fine folks have spent years engineering great working and handling kits that are easy to install, and provide you with all the necessary bits to put together a quality and safe truck. One that will also provide good resale value if and when that time arises. IMHO, this is one of the best ones out there. Heidts Hot Rod & Muscle Car Parts - HEIDTS Superide II Truck - Complete Package It's a huge step above the standard, lo-buck kits, but worth it.
You can use the original steering column if you want to retain the stock looking interior. It just takes a little bit of doing making a lower column floor mount, and modifying the end of the column with a shaft bearing after you cut it away from the old steering box. Most people want something more modern, adding tilt, turn signals, etc., and swap the column with something newer. Either will install with the special u-joints and shaft pieces made for that application.
For the brake master cylinder/power booster, the original won't work. You'll need one that will work with the new, front disc brakes that come with that pretty, new MII kit. The kits also have the option of going with manual or power rack and pinion steering. If you opt for power, there's the obvious pump you'll have to install on the engine, as well.
None of this stuff is hard, really. Lots of people have done it, so it's a well traveled path. But to do it right, it does take a few dollars and some welding/fabrication skills, or a friend with some. And there's plenty of people here to pick the brains from along the way if you get stuck or lost.
So there you go. Exact change only, please. No refunds.
Good luck.
Just think of the upside of IFS though, better brakes, handling and usually power steering.
Wayne, you always come thru...
So, just those 2 itmes (brake master cylinder/power booster and the power rack and pinion steering?)
No other surprises?
Sounds dooable!
I'm going to give others a chance to chip in.
Paul
________________________________
46 Ford Tudor - Street Rod
48 Ford F1 - Darkside
Happiness: 3 pedals and a 5 speed.
The sad but honest truth is that I have already shortened the drive shaft Chris. If I end up investing in the time and money for the IFS upgrade - which I probably will - I'm certain I can come up with another one, though I hope I don't need to.
Paul
