400ci Running rough
Old Aug 4, 2011 | 03:41 PM
Andrew7dg's Avatar
Andrew7dg
400ci Running rough
1981 Ford- F350 dually with the 400ci engine
I was pulling stumps out with the truck and it seemed suddenly that it doesn't want to idle properly. It also seems to have loosed a little power I think
It did get a little hot on the temp gauge when pulling stumps
I am going to check the timing because it does feel kind of like a spark issue
Which brings me onto another question. I would like to upgrade the coil to something else. Something that I can find in the junkyard. What can I used to get me a better spark?
What else can I check?
Could it be a carb issue?
Old Aug 4, 2011 | 07:18 PM
Franklin2's Avatar
Franklin2
Keep the same coil you have. Any other coil can be hard on the ignition box and make it get hot.
Old Aug 7, 2011 | 10:17 PM
Andrew7dg's Avatar
Andrew7dg
worked on the truck a little today,
put new spark plugs
cap and rotor
Still idling rough.
Checked vacuum lines and the vacuum line to the power booster for the brakes was loose.
I think it fixed it. Kind of hard to tell with the cam I have in it.
It is idling by itself again after playing with the idle screw a little
It is running better I believe with the new spark plugs
Old Aug 24, 2011 | 10:37 AM
Andrew7dg's Avatar
Andrew7dg
Just wanted to post the fix of the rough engine problems
I had a bad ground from the battery post to the engine. Put new cable on there and engine ran A LOT better. So I am making sure now that there is a proper ground to the battery to engine, engine to chassis, and chassis to battery. That should solve some running and electrical issues.
Roll
Jul 17, 2019 03:59 PM
Longh
Oct 26, 2018 10:58 PM
Trevor.801
Dec 28, 2012 08:57 AM
adelyser
Oct 15, 2003 06:42 PM
JamesH
Feb 7, 2003 03:32 PM
