2003 f250
Old Aug 3, 2011 | 09:40 PM
djhecker15's Avatar
djhecker15
2003 f250
ok guys i know for sure my 6.0 is getting fuel but its still not starting what would be the next thing to check ?
Old Aug 3, 2011 | 10:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
What is it doing? Does it crank?
Old Aug 3, 2011 | 11:10 PM
djhecker15's Avatar
djhecker15
it just cranks thats it .... it wont even try to start
Old Aug 3, 2011 | 11:14 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Are you getting any dtc?
Check these:
IPR (injection pressure regulator).. its located in the HPOP case below the Turbo. make sure there are no shorts visible and the plug is tight..
ICP(injection control pressure). i belive is in the the RH valve cover.. check same as above. also with the key on engine off it should see around .2 volts.
Also, read this and check for leaks.
DTS Articles - 6.0L ICP System Leaks
Old Aug 3, 2011 | 11:18 PM
djhecker15's Avatar
djhecker15
ok i read read here if i unplug the icp my truck will start if that is the pro have u heard of that and do u know if its true ?
Old Aug 3, 2011 | 11:19 PM
djhecker15's Avatar
djhecker15
dtc? ????????
Old Aug 3, 2011 | 11:20 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If unplugging it solves it, it probably needs to be replaced.
dtc? ????????
Diagnostic trouble code, sorry. The Check Engine Light codes.
Old Aug 3, 2011 | 11:26 PM
djhecker15's Avatar
djhecker15
i dont have a scanner is there a paper clip trick to get the light to flash ?
Old Aug 3, 2011 | 11:28 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You'll need a scanner. Check with your local auto parts stores. Some will scan for free, but they usually cant read the FORD specific codes. But will lead you in the right direction.
Old Aug 3, 2011 | 11:33 PM
djhecker15's Avatar
djhecker15
ok yea ive been checking the autopart store to buy one but i dont know which is the best to get i cant have them scan it it stick in my yard lol this sucks so much i just got this truck 3 mouths ago and i was takeing her in at 8 am this moring to ford to have it checked out
how do u send a pm msg ?
Old Aug 3, 2011 | 11:39 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Click on someones name and if youre allowed to send a message it will show up there. You need to have a specific number of posts first. I think its 25 tho
Old Aug 4, 2011 | 07:52 AM
Unrealo4's Avatar
Unrealo4
You really should post this in the 6.0 forum. Also read the no start checklist in the 6.0 tech folder.
Old Aug 4, 2011 | 08:36 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Aug 4, 2011 | 08:37 AM
bismic's Avatar
bismic
How many posts for this same issue have you posted? You should pick one and have the others deleted IMO.
From one of the other two threads:
Go through this checklist:
https://www.ford-trucks.com/forums/87...condition.html
Here is a guide that will help you know where all the components are:
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
As Benny said, before doing anything get the codes read if you can and get both batteries charged up and LOAD TESTED (individually). Replace them both if even one is bad.
Then check FICM voltage Key-On-Engine-off (KOEO). Then check it when cranking:
https://www.ford-trucks.com/forums/89...procedure.html
Try disconnecting the ICP sensor and re-starting before you mess w/ getting the ICP voltage. If it starts w/ the ICP sensor unplugged, then you need a new sensor AND connector. Here are two threads on how to swap the sensor and connector:
https://www.ford-trucks.com/forums/85...with-6-0l.html
https://www.ford-trucks.com/forums/86...ml#post7693493
The best tool for troubleshooting on your own is an Autoenginuity. It is fairly expensive. The ScanGaugeII is much cheaper and very good. It can help you identify an issue w/ the high pressure oil system (which is what you are looking for when you try to get voltages from the ICP sensor). You can get it quickly at Autozone (apprx $170), or get it a little cheaper by joining (free) cleanmpg.com and requesting it through their forum ($135).
Old Aug 4, 2011 | 08:50 AM
powerstroke72
I sent him a PM directing him back to this thread Mark. Hopefully, he'll be back to check in on it. I've moved several of these out of the SD forum trying to get him some help. Let's see if this works.
As always, thanks a million for helping out.
WBuhrig
Jan 31, 2017 09:11 PM
Moeford1996
13
Mar 14, 2014 10:13 PM
kyflaresideon20s
Oct 11, 2011 09:30 PM
sgtbraddick
Feb 1, 2011 07:58 PM
Bill Garcia
Jun 5, 2009 09:54 AM
