code p1111
Old Aug 3, 2011 | 09:10 PM
96obssuperduty's Avatar
96obssuperduty
Exclamation code p1111
have a 96 7.3...I am having problems .the check engine lite comes on and the truck starts running rough and clatering...i have replaced lift pump icp and cam sensor ... very intermittent and only does it when the truck has been idleing not while driving......please help?
Old Aug 3, 2011 | 09:17 PM
pjwoolw's Avatar
pjwoolw
What are you using to scan it? P1111 is an all is good code.
Old Aug 3, 2011 | 09:42 PM
pontiacross's Avatar
pontiacross
IF I remember correctly like he said that code means nothing.
but it sounds like you have an under the valve cover harness burnt.
Old Aug 3, 2011 | 10:02 PM
96obssuperduty
i am using edge scaner
Old Aug 3, 2011 | 10:05 PM
96obssuperduty
never really had any problems prior ....250,000 miles..valvecovers have never been off.....funny thing is since lift pump and tightening fuel filter cap wont throw it now... let it run for about thirty min no probs....prior to pump replacement still had 55 psi for fuel press
Old Aug 3, 2011 | 11:42 PM
ccarrier's Avatar
ccarrier
p1111= all systems pass
get rid of the edge asap
Old Aug 5, 2011 | 08:42 PM
96obssuperduty
good call ended up havin wire harness issues on motor side at valve cover plug all good now ..besides the edge chip has worked awsome for 5 plus years
Old Aug 5, 2011 | 08:47 PM
fordpride's Avatar
fordpride
Good to hear you got it fixed.
A few people here have had to buy a new PCM because of the EDGE.Good to see you have had good luck with it but custom tunes would be better for your truck
Old Aug 5, 2011 | 08:55 PM
96obssuperduty
have an 02 stroker also with 5inch straight pipe from down pipe..upgraded turbo and hyprtech chip .........have new ad injectors want to put in 96 what all will i need besdes new hipresspump
Old Aug 5, 2011 | 09:35 PM
fordpride's Avatar
fordpride
You will need to get a custom chip for your truck burned for split shot injectors cause the stock one are single shots
Old Aug 5, 2011 | 09:41 PM
96obssuperduty
figured as much possibly gonna get local diesel shop to reflash so can run newer injectors
Old Aug 5, 2011 | 09:49 PM
fordpride's Avatar
fordpride
You could send the PCM to DP Tuner and have them flash a custom on it for I think it's 75 bucks
sandyc
6.7L Power Stroke Diesel
May 30, 2018 12:21 PM
geta4x4
Feb 28, 2009 06:56 AM
rmarion
1983 - 2012 Ranger & B-Series
Sep 19, 2004 07:51 PM
