have a 96 7.3...I am having problems .the check engine lite comes on and the truck starts running rough and clatering...i have replaced lift pump icp and cam sensor ... very intermittent and only does it when the truck has been idleing not while driving......please help?
never really had any problems prior ....250,000 miles..valvecovers have never been off.....funny thing is since lift pump and tightening fuel filter cap wont throw it now... let it run for about thirty min no probs....prior to pump replacement still had 55 psi for fuel press
A few people here have had to buy a new PCM because of the EDGE.Good to see you have had good luck with it but custom tunes would be better for your truck
have an 02 stroker also with 5inch straight pipe from down pipe..upgraded turbo and hyprtech chip .........have new ad injectors want to put in 96 what all will i need besdes new hipresspump
