Sponsored by: Real Truck
fuse block help!!!
Old Aug 3, 2011 | 08:14 AM
doorider's Avatar
doorider
fuse block help!!!
Have a 99 superduty f350 with the 5.4. Been gavin problems with speedo, turn signals, abs and engine missing and all due to the fuse block under the dash cause if I wiggle stuff on it I regain all for short time. Been told there known for getting wet and corroding? Any truth to this at all? And would a fuse block out of a 99 diesel be the same? Please help thanks
Old Aug 3, 2011 | 08:48 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, they corrode if they get wet. They are not "known" for it, but like any modern vehicle leaks and floods will cause issues.
Old Aug 3, 2011 | 03:23 PM
bpounds's Avatar
bpounds
They are known for a windshield/cowling area leak, which can run down on the fuse block. So if yours is corroded I would get a shop to check for leaks first. Then just replace the whole block. I think they are a couple hundred $$ from partsguyed.com. You don't want to replace it and then see it get wet again this winter.
Old Aug 3, 2011 | 03:58 PM
doorider's Avatar
doorider
Do u know if there hard to replace?
Old Aug 3, 2011 | 04:10 PM
bpounds's Avatar
bpounds
Everything just plugs in. At least it does on my '06. I think it should be very easy. It is called a Central Junction Block.
It actually has relays built internal which are not user replaceable, so the block is meant to be replaced when necessary.
Old Aug 3, 2011 | 08:08 PM
doorider's Avatar
doorider
Would the fuse block outta same year truck but diesel be the same
Old Aug 4, 2011 | 09:21 AM
bpounds's Avatar
bpounds
Sorry, don't know. I would not bet on it being the same.
ms1780
Dec 7, 2018 11:53 PM
Crash1-2
Nov 5, 2009 11:42 AM
tribune
1997 - 2003 F150
Jun 23, 2006 07:04 AM
