engine oil leak... the dye method
Old Aug 3, 2011 | 07:08 AM
fishmanndotcom's Avatar
fishmanndotcom
ok so i cannot find my leak anywhere. its not a drip here and there... when i park it leaves a puddle the size of a saucer plate. so i have decided to try using a dye of some sort to try and pinpoint where it is coming from. i really dont like the idea of the dye mixing in with the oil and running through the motor but i am about out of ideas. and if i do have a leak from a major component i will pull the motor but not if i dont have to.
here is a list of what i know its not:
valve cover/gasket
oil rail end plug
hpop
oil rail plugs
turbo pedastal
oil pan (when the clutch cover rubs a hole in it)
fuel pump/bowl (i know its not oil but diesel looks like oil once it makes its way to the bottom of the motor)
do you guys suggest one brand or type over another at dyes? i dont mind spending a little more on a higher quality brand, esp if it is rated for the PSD's.
thanks as always guys
-cutts-
Old Aug 3, 2011 | 07:35 AM
Talyn's Avatar
Talyn
I'd look over the oil cooler. Where its at, its hard to tell its leaking because the fan blows everything everywhere.
I didn't even know mine was leaking because I had another leak leaking over top of the oil cooler. Thought I fixed my leaks, and its still leaking, cause of the oil cooler.
It gathers on the pan and drips from the pan, so it made it hard to find.
A few times with the power washer helped me find it.
Old Aug 3, 2011 | 11:47 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
It could be the pan seal not a rub.
Very rare but could be the rear main seal
my 0.02
Deagle12
Modular V10 (6.8l)
Dec 18, 2017 01:18 PM
Mcnitchell
Apr 29, 2015 10:42 AM
Walker307
25
Mar 23, 2013 09:51 AM
BIG R
Mar 9, 2008 09:27 PM
bonechief
Sep 19, 2005 08:48 AM
