Matching a turbo with new nozzles
Hello,
I am tearing my truck apart (studs/oil cooler)to upgrade the turbo with a GT3788VA. I seem to have a few troubles with my sticks currently and am wondering if I decided to upgrade, what is a good matched set to go with along with the new turbo upgrade. From what I understand, the stock nozzles are 140cc detuned to 125cc.......maybe I am incorrect. I hear that upgrading nozzles with this new turbo, along with MATT's tuning, is the best way to take advantage of the new turbo . I tow very heavy at times and and want to match everything with the stock IC setup I have and obviously not melt my truck in the meantine. Any ideas or comments are welcomed.
PS the tear apart wont be for a few months...
Thanks
Joe
Thanks
Joe
npccpartsman is right.....about the injectors.....
To the OP...I've been down this road...the stock sticks worked fine with tuning....but whoa! boy did the 155's make a difference...I bet it would be even more so with 190's....
That turbo works with stock sticks just fine but to truly unleash all its glory needs more fuel....
I went 155's because I still use my truck to tow heavy...sometimes over 15k.... and my EGT's are just fine with the right tune...
JESTER......
What setup do you have (turbo, injectors, tuning) and where did you get your injectors?
What type of EGT's are you seeing under the most extremes?
It sounds to me that we tow about the same. I understand that the stock injector will work great, but a heavier flowing injector would flow better and without straining the injector itself. I have a few questions:
-with the above statement....am I correct?
-is a regulated return necessary?
-where and from whom do I get nozzles?
Any other opinios are welcomed.
Thanks
Thanks
I bought OEM re-man injectors and did the work myself.......to the same dimensions and tolerances as a standard 155....I cannot disclose who gave me those dimensions...sorry
I use the garret 63mm powermax turbo...03 version
If I'm towing its bout 950-1000 deg's....stuffed to the rug on an off ram or climbing a steep grade...its 1300 deg's...Like above I have never passed 1400...
The only fuel mod's I have done is the blue spring update, and a fuel pressure gauge. other than that its stock. no problems running out of pressure/volume.
The injector isn't under any strain. I'm not sure how to explain it in a way for you to understand. The stock injector has quite a bit left from factory tuning. Simply adding nozzles is a waste of money. Period. Casserly uses stock nozzles on his 155's because he's flowed LOTS of them and they're very adequate. Larger nozzles are just going to make you have worse combustion because the fuel won't have a chance to atomize as well. It will smoke more, run hotter and drive worse.
I think just the addition of the turbo I described will be sufficient...what do you think about that choice?
I think the addition of the powermax would be great and PLEASE don't misunderstand me about the sticks. I'm NOT saying don't get bigger injectors, but if you're going to do it then do it right so that you'll really have something. 155's and a powermax is a great combination for daily driving, pulling heavy, AND doing a little hot rodding if you want, but just putting nozzles on is throwing your money away.
Nozzles--the tips of the injectors where the fuel squirts out. The come basically in 3 different sizes--50% (stock-155's), 75% (175's and 190's) and 100% (205's and larger). Then there is the barrel of the injector that holds the volume of fuel that you want to inject into the cylinder through the nozzle. A stock injector barrel holds ~135 cc's of fuel. To get a bigger volume of fuel the barrel and/or plunger (that pushes the fuel out of the barrel) has to be modified in some form or fashion. Simply putting a larger nozzle on an injector won't get you a bigger injector.
joe blow- call up warren diesel! he just "rebuilt" a set of stock injectors for a buddy of mine and put new stock nossles on there and made the body of the injector a 155cc. it runs so smooth and egts are great! best part is he only charged 500 for all 8. great guy to deal with and does great work!!!!
