melted pos conection off
Old Aug 2, 2011 | 10:35 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Turned over the Ex to drive her for a bit,been sitting for a week,cranked slow for around 20 sec or less then quit. Popped the hood n the positive connection on the drivers battery was melted off. What causes this? Bad ground? I just replaced all the cables,connectors,batteries,alternator,grounds,and starter. Everthing is still tight and clean. Little corrosion on the neg of the same battery. Boggled
Old Aug 2, 2011 | 10:39 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Theres probably a short somewhere. That will cause current to flow constantly.
DIY home science test: Take two 9v batterys and clip them together. They will warm up. Same principle.
Old Aug 2, 2011 | 10:40 PM
hotroddsl's Avatar
hotroddsl
That sounds like an internal shorted battery!
Old Aug 2, 2011 | 10:59 PM
diesel-fitter-bum01
I have a new set of interstates,but I'm not too sure i want to put them in yet if its doing this.
Old Aug 2, 2011 | 11:02 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
New = Warranty
Old Aug 2, 2011 | 11:05 PM
snakedoc's Avatar
snakedoc
if you have a bad connection it will make the amps go up and that makes the heat go up. there may have been something on the wire where it was clamped that may be the problem.
Old Aug 2, 2011 | 11:12 PM
diesel-fitter-bum01
I will double check it all again tomorrow before I crimp another connector on there. The batteries that I have in there now are warranty. Less than a year old. Will have them checked too.
jimmmack
Dec 30, 2014 06:27 PM
Jim-4903
Apr 6, 2014 09:28 AM
User 93024
2004 - 2008 F150
Nov 24, 2013 08:55 AM
nothercrash
Jan 10, 2011 09:39 PM
dgeesaman
Jan 1, 2009 09:47 PM
