Automatic Fuel Transfer!
Old Aug 2, 2011 | 07:12 PM
Matt2654's Avatar
Matt2654
Angry Automatic Fuel Transfer!
Hello Everyone,
I'm having some trouble with the fuel system. I have a 1996 F250,2WD,7.5L and 2 tanks. The problem I have is, when under a heavy throttle condition such as merging into highway or passing, the "excess" gas from the rear tank is going into the front tank.
I would start with the rear tank, and when driving to pass or merge I would notice that after a little bit of doing this, my gas gauge shows a pretty good amount of fuel used. Thinking that is normal for the size of my engine, would refuel and be on my way. One day I switched to the front tank that had about a 1/4 tank just a couple of days ago only to find my missing gas! The front has about 1/2 tank of gas and I did not put gas in the front tank!
Another problem I have with the rear tank is sometimes driving down the road, truck would buck, stall and start right up without turning the key. Don't know if there is a connection with all of my problems. The fuel filter on the rail was replaced as part of my normal maintenance.
Old Aug 2, 2011 | 09:47 PM
rla2005's Avatar
rla2005
Common problem with this vintage truck. Search this forum with keyword fuel cross flow. Many threads pop up every single day with this problem.
Old Aug 3, 2011 | 07:37 AM
subford's Avatar
subford
You have a bad Front FDM.
FDM:
Old Aug 3, 2011 | 08:43 AM
Conanski's Avatar
Conanski
Yep.. and if it happens at all it's happening all the time at all engine speeds. The check valves that are supposed to prevent this are located inside the fuel delivery module inside each tank so you'll have to drop the tank to fix it.
Old Aug 3, 2011 | 08:52 AM
ChristopherN's Avatar
ChristopherN
So when this happens when you're using the rear tank like me, and it fills the front. Is the rear FDM at fault or the front?
Old Aug 3, 2011 | 08:59 AM
Conanski's Avatar
Conanski
The tank that recieves fuel when it's not supposed to is the one with the bad FDM.. which in your case is the front.
540milotalon
Sep 28, 2014 07:24 PM
samcage
Jun 22, 2011 11:58 PM
Anhbe
Aug 26, 2006 07:34 PM
scozim
Jun 11, 2006 12:14 AM
pdsq89f150
Apr 17, 2003 01:21 AM
