Aerostar Ford Aerostar
Radiator
Old Apr 22, 2006 | 07:56 PM
gwm's Avatar
gwm
Radiator
I have an 92' Aerstar. It has been running hotter than normal I had to replace the rad and the hoses also replaced the thermostat, rad cap my resevoir keeps filing up and over flowing. any advice would be appreciated.
Old Apr 22, 2006 | 08:18 PM
99f350sd's Avatar
99f350sd
Sounds like you may have to do a water pump. Maybe the fins are gone on it. And how about your fan clutch?
Dick
Old Apr 22, 2006 | 08:46 PM
Aeromac121's Avatar
Aeromac121
Just curious, did this problem start before or after the new radiator? Does the heater blow hot air? Does the air blowing out of the radiator fan feel hot?
Old Apr 22, 2006 | 08:54 PM
gwm's Avatar
gwm
It happened about the same time. I had a leak in the old radiator. I was leaning towards the water pump.
Old Apr 22, 2006 | 11:48 PM
Bear River's Avatar
Bear River
Former ******
The water pump can be tested you know. Look on the underside of the water pump. If you can see signs of leakage fromt he weep hole, then you need a new pump. If that is good, take the upper hose (with the system at opperateing temperature) and squeeze it. If the pump is good, you will feel a surge through the hose as you release it.
Old Apr 23, 2006 | 02:59 AM
96_4wdr's Avatar
96_4wdr
any signs of overheating on temp gauge or rapid fluctuations in temp gauge while driving?
have system pressure tested for stable pressure
may have wrong cap for radiator neck, sometimes caps get switched by customers or counter guys when searching for right cap
check lower return hose for inner spring that prevents collapse by suction from pump
Aero V6's can be tempermental to air purge...you may have an air bubble trapped in block or heads that creates steam bubbles passed thru to radiator which are passed out along with coolant to overflow tank from overpressure in radiator
run front end up on ramps on hill...front 2>3 ft higher than rear....fill overflow tank to 1/3>1/2.....take off radiator cap....run engine until hot....fill tank...crank cap down to first click only....run engine 20-30 minutes, revving ocassionally to 3k rpm....crank cap to last click and lock....shut off engine and let cool
Old Apr 23, 2006 | 08:20 AM
gwm's Avatar
gwm
When filing the system up with coolant, after cranking the van for a bout 2 to 3 minutes coolant startes burping out of the top without the cap on, the van never reaches operating temp.
Old Apr 23, 2006 | 08:44 AM
99f350sd's Avatar
99f350sd
You mean running the van don't you. Without the cap on and engine running coolant will come out as it expands.
Old Apr 23, 2006 | 08:53 AM
gwm's Avatar
gwm
Yes. After filing the rad up, start the van the coolant drops then i top it off and about 2 to 3 minutes it starts overflowing without the cap.
Old Apr 23, 2006 | 09:09 AM
99f350sd's Avatar
99f350sd
Thats normal..
Old Apr 23, 2006 | 09:11 AM
gwm's Avatar
gwm
But it never stops, my overflow fills up and overflows.
Old Apr 23, 2006 | 09:14 AM
gwm's Avatar
gwm
I thought it was my rad cap but this is my second cap that I put on it.
Old Apr 23, 2006 | 09:19 AM
99f350sd's Avatar
99f350sd
You have to exceed 10 or so psi to blow off the cap and have coolant go into the tank. Your hoses should be tite tite when this is happening. If it happens before the engine gets hot you may have a head gasket failure blowing compression into the cooling system..
Dick
Old Apr 23, 2006 | 09:30 AM
gwm's Avatar
gwm
Thanks, can a garage do a pressure test on the system?
Old Apr 23, 2006 | 09:35 AM
99f350sd's Avatar
99f350sd
Yes they can usually.. You can look for bubbles in the coolant Thats another way to tell you have a bad headgasket. Like I said if the hoses are getting tight before the engine gets hot you have a bad head gasket most likely. You will see bubbles in the water and they won't stop..If you watch before you put the cap on.
Dick
