When did ford start making the 300 cid ? And how hard is it to go from efi to a carb. ? THANKS FOR ANY INFO this is my first ford so i might be asking some really dumb questions
1965.
Just swap out intake manifolds and distributors ( Duraspark II distributor & ignition module out of an early 80's 300 is the easiest/ cheapest way to go ) .
And you'll have to run an electric fuel pump with a fuel pressure regulator that will lower the pressure enough to work with a carb. Depending on your carb that is usually in the 3-7 psi range. That's about it.
