TPS ?
Old Aug 1, 2011 | 09:17 AM
JOHNSHO's Avatar
JOHNSHO
TPS ?
95 f250 5.8
My closed throttle reading is "1.1" volts.
The WOT is 4.6 volts. Has a smooth transition thoughout closed to open.
Would the "1.1" my problematic high idle. New tps.
Thanks and have a Blessed DaY!
Jphn
Old Aug 1, 2011 | 10:14 AM
'89F2urd's Avatar
'89F2urd
i guess what you are saying is that you have an erratic idle issue?
get yourself a haines or a chilton manual. it has the information you are lookin for, but not just for the tps, for all of the sensors. the manuals give you easy step-by-step voltage/resistance tests for each sensor. so ya dont have to sit here and wait for someone to crack their manuals out to tell you.
Old Aug 1, 2011 | 12:38 PM
Lazy K's Avatar
Lazy K
http://www.fordfuelinjection.com/?p=30 Read through this link.
Old Aug 1, 2011 | 05:38 PM
JOHNSHO's Avatar
JOHNSHO
You read it wrong!
I SAID "HIGH" IDLE.
I come to this forum to ask after I have looked through the manuels, if that is ok with you.
Have a Blessed Day
John
Old Aug 1, 2011 | 06:34 PM
zemus420's Avatar
zemus420
that 1.1v could be the problem closed should read 0.6-1.0v
Old Aug 1, 2011 | 06:51 PM
rla2005's Avatar
rla2005
I agree that closed throttle voltage is too high. I would bet if you ran the KOEO/CM tests you would see a TPS code. Did you have a high idle before replacing the TPS? What is the idle RPM with the IAC disconnected?
liberty2701
Jul 6, 2013 04:55 PM
javi2001
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 5, 2012 12:44 PM
dude998866
Jul 12, 2008 01:38 AM
davetmd
Nov 1, 2004 09:56 PM
