Timing chain cover replacement
Old Jul 30, 2011 | 11:43 PM
.87-ford's Avatar
.87-ford
I rebuilt the engine in my 87 f-150 a little over a year ago...it used to be efi but i slapped a good old holley four barrel on it... in doiong so i had to change my timing chain cover to an older one to get the fuel pump to bolt on to it...it came off of a seventies something motor and has some pitting on it and about three onths ago i found it leaking between the cover and the block...replaced the gasket and its leaking in the same place again...so the question is what years could i find a newer timing chain cover to swap it out for? thanks for the help
Old Jul 31, 2011 | 10:23 AM
lsrx101's Avatar
lsrx101
I'm going to try and move this to the appropriate forum.
Old Aug 1, 2011 | 07:07 PM
dustybumpers's Avatar
dustybumpers
Some of the replacments are for all years. That bieng said, I would think any cover below 84 would work for you
chrisjr2287
Feb 12, 2023 09:57 AM
guy 466
Dec 2, 2010 04:33 PM
HighRollin
Nov 26, 2004 09:06 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
Nov 9, 2004 12:44 PM
