Here's a little fun!
Old Jul 31, 2011 | 10:30 PM
Blackbeltdually's Avatar
Blackbeltdually
Here is what a bored man does with his time. I worked at getting this rig in the truck. Had to build a "deck" inside box to raise floor to wheel well height. Then worked to see if rig would fit. It won't go by about an inch! The lower faring in the Goldwing gets caught by about an inch and that was trying to load out of my garage. I have a few more ideas. I will get that thing in there and it will go with us on vacations! Wish me luck!
Old Jul 31, 2011 | 11:03 PM
guitarpicr's Avatar
guitarpicr
Can u remove the faring? Not sure what is making it not fit. Good Luck either way. I would def want that on vacation with me also
Old Aug 1, 2011 | 06:49 AM
farmdad's Avatar
farmdad
Just a thought, build the deck to the same height as the top of the box. I know that would give you more wind resistance but the bike would fit with no constrictions on the width. Then you could store stuff under the deck. Just can't separate boys and their toys....
Old Aug 1, 2011 | 10:30 AM
DieselCamper01's Avatar
DieselCamper01
I like Mark's idea. Gives you some storage then. No way to easily take that fairing off.
Old Aug 1, 2011 | 02:25 PM
timmyboy76's Avatar
timmyboy76
just a thought
if handy with a welder, i'd fab up a metal skeleton frame, so it can withhold the "raised" floor, since you cannot support the wait on the wheel wells anymore. Using the 6 holes already in the bed, for a 5th hitch, run your supports length off those, then build out/up from them....? With the floor being a tad higher then the wells.
Yahiko
Oct 28, 2013 08:57 PM
mzender
2004 - 2008 F150
Jun 1, 2012 01:43 PM
bubba_3711
30
Mar 13, 2012 01:18 AM
XolieX
2004 - 2008 F150
47
May 14, 2008 08:20 AM
fisher_of_man
21
Oct 19, 2007 02:23 PM
