2014 f150 Headlamp adjustement
Old 01-29-2015, 09:51 AM
Blk Rhino's Avatar
Blk Rhino
Blk Rhino is offline
Hey There, i am going to add a 2" lift to the front of my 2014 F150 Ext. Cab and it will throw off the Headlamps. My question is, Is it difficult to adjust the headlamp beam ?...In the old days it was just a few screws, but wanted to find out if there was any issues or tricks with my new truck.
Old 01-29-2015, 10:18 AM
Badass69's Avatar
Badass69
Badass69 is offline
It's simpler than all get out on these trucks. It's one screw...... up and down only, that's it. If you are happy with the lights as is you can just mark where they are on a door from a flat surface (supposed to be done at 25') and then just adjust them down to match where they were before after the lift is on.
Old 01-29-2015, 11:07 AM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
The procedure to align the headlights is detailed in the owner's manual. *Beginning on page 250 - ADJUSTING THE HEADLAMPS
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 01-29-2015, 02:03 PM
Blk Rhino's Avatar
Blk Rhino
Thanks alot for the info. on adjusting the headlights, all the information was helpful...My Black 2014 F150 XLT Ext. Cab goes into the shop on monday for a 2"lift, and Dune 524 20" wheels, i'm selling my stock chrome 18" wheels and Goodyear tires with 10,000 miles on them, and going with Goodyear Duratraks...Hope it all works out, i'll keep you posted and get a pic.
Old 01-29-2015, 06:17 PM
muziclova's Avatar
muziclova
muziclova is offline
Does putting in the lift kit void the warranty??And adding bigger tires?
Old 01-30-2015, 10:14 AM
Blk Rhino's Avatar
Blk Rhino
Here’s what the dealer told me, he said, most people do think that adding after-market parts will void a new vehicle’s warranty. But it’s not true at all, but if an after-market part causes an issue or problem then per that problem it won’t be covered under warranty. He said it’s against federal law to void a warranty because someone uses an after-market part.
I also found this blurb below about the MMW act.
The Magnuson Moss-Warranty Act
The Magnuson-Moss warranty act is a federal law enacted in 1975 that makes it illegal for auto manufacturers (or any manufacturer of consumer products, for that matter) to void a warranty simply because the owner of the vehicle adds an after-market product to a vehicle. The law states that manufacturers have to repair a vehicle problem UNLESS they can prove the problem was caused by an after-market part.
Old 01-30-2015, 10:33 AM
SBV45's Avatar
SBV45
SBV45 is offline
I recommend you get your TCM adjusted to the new tire size. Besides your speedometer being off, the new tires can compound problems with shifting like harsh downshifts, etc
See Tire Size Calculator - Compare Tire Sizes
Old 01-31-2015, 10:17 PM
Buck268's Avatar
Buck268
Buck268 is offline
FWIW i just about have my headlight adjustment maxed out (downwards) with the Bilstein 5100's leveling the front. I suspect they (bilsteins) are at max setting, though.
Old 02-20-2015, 04:08 PM
Blk Rhino's Avatar
Blk Rhino
I'm looking for a decent tcm adjustment tool to use to reconfigure my Truck for the bigger tires i added, and it would be great if the tool could do more than just the TCM adjustment...anyone used anything that may help.
2014 f150 285/65/20 ...Thanks in advance
eriebasin
2009 - 2014 F150
08-22-2015 08:42 AM
0ldV8truck
1947 and Older Ford Trucks
22
03-23-2013 10:21 PM
Stangfire
2009 - 2014 F150
16
03-21-2013 03:40 PM
jimmy-six
2009 - 2014 F150
12-13-2012 08:57 AM
joey schaffner
2009 - 2014 F150
11-17-2012 11:41 AM
Quick Reply: 2014 f150 Headlamp adjustement
