1978 - 1996 Big Bronco
Operation: Zebra build
Old 08-18-2012, 07:46 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Yeah, can't take it with you when you go so might as well have fun while you're here.
  #767
Old 08-18-2012, 08:37 PM
78Explorer's Avatar
78Explorer
78Explorer is offline
Originally Posted by Edgethis
I would have done it today except that the parts for the coupe came in today. Shelled out an arm for these special headlights.
O boy the way, I've officially found my next project. Once I get things paid off. This thing just makes me drool.....
’33 Hot Rod | | Factory Five RacingFactory Five Racing
Brett -
That '33 kit is some kinda' COOL!!! I'd love to build/own one..but with the Coyote 5.0 and Tremec trans, I'd be into it close to $30k BEFORE wheels/tires/rear-end/paint...TOO MUCH for this old retired fart!
What do the "special headlights" look like?
I got Deb's '68 out the other day...drove it a bit, changed the oil, topped off the coolant and put it away for a few more days. Gotta get it back out this week and give it some of my "elbow grease" to get it ready for Somernites Cruise next Saturday...Mustangs are the featured car this month.
Here are a few shots of it that I took while I had it out this week:
  #768
Old 08-18-2012, 08:45 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Thats a nice looking pair of cars you got there.
The '33 coupe is a dream, but who knows.
Here are my lights. Tri-Bar by Scott Drake.
http://www.flickr.com/photos/62639173@N03/7810854540/http://www.flickr.com/photos/62639173@N03/7810854540/ by http://www.flickr.com/people/62639173@N03/, on Flickr
http://www.flickr.com/photos/62639173@N03/7811678974/http://www.flickr.com/photos/62639173@N03/7811678974/ by http://www.flickr.com/people/62639173@N03/, on Flickr
  #769
Old 08-18-2012, 09:02 PM
78Explorer's Avatar
78Explorer
Thanks! Right back atcha!
How much $$ are the tri-bars? They look GREAT!
  #770
Old 08-18-2012, 09:08 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
looks nice Brett. eventually I have to take a voltage test on my alternator for tgm my lights are dim and flickering a bit, or pulsing. someone else from the Washington chapter has recommended some other headlights for me that I might invest in down the road.
  #771
Old 08-18-2012, 09:58 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
The lights are pretty expensive at $85 a piece, however Cj Pony Parts has a sale right now, get a $30 gift card for every $100, so I bought these and an armrest to help finish gathering parts for my door panels restore. Got a $60 gift card, that pays for half of the LED tail lights I want.
C5ZZ-13007-LBB Mustang Scott Drake Headlight Bulb Blue Halogen Tri-Bar 1965-1973 | CJ Pony Parts
They also have a set with clear bulbs, I went with a blue tint.
  #772
Old 08-18-2012, 10:02 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
I think that every older vehicle needs to look into a relay set for the headlights, they really help. I'm going to see if RJMs kit will work for my Mustang, if so then I may buy 2 sets, one for the coupe and one for the Zebra.
I've seen a set-up similiar to the ones I posted for the square bulb set-up. I'd say look for that or get a set of Silverstars with the relay mod.
  #773
Old 08-18-2012, 11:03 PM
GruesomeJeans
I'll have to check up on this relay mod. I have heard word about it from fellows like you guys but i don't quite understand it. I know the basics about things like capacitors and fuses and their purpose but relays, lets say that part of auto tech class i didn't really pay much attention. I may or may not have been more attentive to the girl sitting next to me But anyways aren't relays switches sort of? Yahinko (WAFTE member who i met out a meet up we set up) was suggesting either a higher amp alt to help with my amp and subs, or trying to retrofit a smaller pulley to increase the rpms of it since ol TGM lopes a little bit till i hit the gas
EDIT: so i found this
http://www.autoshop101.com/forms/hweb2.pdf
I read it a bit, and what i thought was right, a relay is essentially a remote switch. But what i don't understand is how would this help the light flickering? It seems more like i would need a capacitor that would store up the energy to power the lights full on. Though i could be wrong.
  #774
Old 08-19-2012, 07:45 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
RJM Injection Tech — Headlight Harness
A relay takes the load off of your headlight switch, reducing a fire hazard and prolonging the switches life. Also in a kit like Ryans, you get bigger wires going to headlights which allow more current to give the lights the full 12 volts making them brighter.
A higher amp alt is a great option if you can find one cheap. Most aftermarket high amps alts are like 300 and up!! I was lucky and found the diesel alt bolts right up to the 351w and is 130 amps vs my standard 95.
  #775
Old 08-19-2012, 10:23 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
Well can't so the gasket today, its raining so hopefully sometime this week I'll have a chance.
  #776
Old 08-19-2012, 03:17 PM
GruesomeJeans
I see. yeah my alt is for the stock 78 which was about 75 amps I think. I don't think it was meant to run a stereo system though. I'm not sure what other alternators would fit my motor. I can talk to my friendly autozone peeps and see if they have any in store that would work.
  #777
Old 08-24-2012, 04:21 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Work on the Bronco got pushed back again. I crawled under the coupe to get tighten a few bolts I thought were loose causing an slight oil drip. Wrong, everything is leaking, looks like heads gaskets are blown too. So a quick trip to the local Advance and $75 later I have a one piece oil pan gasket and a complete top end gasket set. Already got the pan off, sanded and a fresh coat of Ford blue drying. Hope to have oil pan fixed tonight or early morning. Need to order head bolts for top end.
Hopefully I'll have time to fix the Zebra's header gasket before the end of days come....
  #778
Old 08-24-2012, 05:10 PM
GruesomeJeans
Wow that kinda sucks.. Though we require pictures to live!! Even if is a mustang i think it is fair to say a few pictures won't hurt.
  #779
Old 08-24-2012, 05:12 PM
Bubba Jones's Avatar
Bubba Jones
Bubba Jones is offline
That's coming pretty soon you know. December 21st, 2012. It's OBVIOUS this is the REAL end of the world. The Mayan calendar CLEARLY predicts it is. Since 2000, then 2001 (because 2000 wasn't), and the May 21st thing like last year were all not the end of times, this one FOR SURE is. ........okay maybe not
Anyways, you have an awesome looking coupe, but the Bronco is important too!
  #780
Old 08-24-2012, 05:20 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Haha ask and you shall recieve.
Here is the bottom end of the motor with the pan off. I think I'll go ahead and grab a new oil pump since its right there and its only $15.
http://www.flickr.com/photos/62639173@N03/7853538428/http://www.flickr.com/photos/62639173@N03/7853538428/ by http://www.flickr.com/people/62639173@N03/, on Flickr
This is what I found in the oil pan, not a good thing to find....
http://www.flickr.com/photos/62639173@N03/7853545398/http://www.flickr.com/photos/62639173@N03/7853545398/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Here's the pan and the crossmember with fresh coats of paint!
http://www.flickr.com/photos/62639173@N03/7853540866/http://www.flickr.com/photos/62639173@N03/7853540866/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Here's the patient in the operating room:
http://www.flickr.com/photos/62639173@N03/7853542792/http://www.flickr.com/photos/62639173@N03/7853542792/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Quick Reply: Operation: Zebra build
