'95 engine swap question
Old Jul 31, 2011 | 08:53 PM
insane_goofball's Avatar
insane_goofball
Originally Posted by '89F2urd
get the 351. youll get the same mileage but youll just have more *****. (more ***** + same mileage) > (less ***** + same mileage).
love that math... lol
Old Aug 1, 2011 | 08:01 AM
'89F2urd's Avatar
'89F2urd
its the mathematician in me. . .really helps make points sometimes
even if its just in my own head. . . .
Old Aug 1, 2011 | 09:03 AM
Conanski's Avatar
Conanski
I have done this swap in both directions.
If your truck is MAF(it should be) and you get a complete 5.8 EFI engine this is a direct swap for the most part with a few 5.8 unique parts. Those parts are the flexplate, exhaust manifolds, and Y pipe. The flexplate is unique to the engine/transmission combo.. different offset for each trans and 28oz balance for the 5.8 vs 50oz for the 5.0. The passenger side 5.8 exhaust manifold has an EGR connection that the 5.0 doesn't, and since the 5.8 block is taller and wider the Y pipe is shapd differently. If using headers the 5.0 Y-pipe can be easily modified to fit the motor.
Other than that the stock 5.0 engine wiring will literally plug right into the 5.8 motor and a MAF 5.0 computer will run a stock or lightly modified 5.8(cam or 1.7 rockers and headers) no problems at all. You can expect roughly the same or a littler worse milage in the city but potentially better highway milage and yes the 5.8 produces quite a bit more Tq for towing and hill climbing.
moostadon
Feb 6, 2010 10:30 PM
Calf_roper_John
Jun 22, 2007 12:36 AM
alz
Engine Swaps
41
Dec 15, 2006 10:17 PM
muskrat
13
Nov 20, 2003 07:55 AM
DBF
Nov 10, 2000 04:43 PM
