The coil would be engaged when the switch is on, but not when the ign power is on. If you used a center off dual pole dual throw switch, you could wire a 2nd relay to turn off the ign power. I use relays all the time, they are built for it and the coil doesn't draw much for amperage, so I wouldn't worry about having a relay on whenever the circuit is engaged. It is still better then diodes. Not only do they get hot, but there is a voltage loss across them, so there is still wasted power.
Trust me, I'd prefer not to use them...was worried about 12v back-tracing the wire...let me take another look at the drawing...
I wire the circuit I showed you all the time for an "override" switch for cd players in cars. With the switch off the wire works as normal, when you turn it on it disconnects from ign wire and connects to constant on wire. When you switch it off, it disconnects from constant and goes back to ign. The wire disconnects first, so no chance of back-tracing. With a "make-before-break" switch, you could have that happen, but even then, in most cases of a 12V system, it would not be a big deal.
"make before break" switch?! Ok, you are obviously a little more advanced than I am...my new best friend.
