Stretched seal
Old Jul 30, 2011 | 05:06 PM
Sheryle's Avatar
Sheryle
Stretched seal
Don't mean to be a pest, but this oil cooler operation is all new to me. Here is my latest challenge.
Yesterday, I cleaned parts and reassembled the oil cooler. While I was into it with fairly clean hands I installed the other seals that came with the kit. Today I was putting the oil filter base onto the oil cooler cover and the seals will not stay in place. I thought no problem I will put a thin coat of permatex gasket sealer in the groove. I was wrong..problem...both seals have grown. They will not fit into the groove. Push it in here and it pushes out somewhere else. I have not pulled on or handled them roughly. They appear to have grown overnight.
Has anyone had this happen? What is the solution? What if I cut out a small section and glued it back together??? Thanks for reading and helping me through this.
Old Jul 30, 2011 | 05:08 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You should have used engine oil for lube. You need to buy a new "O" ring......a cut will INSURE it leaking!
Old Jul 30, 2011 | 05:14 PM
BLADE35's Avatar
BLADE35
dont cut it
all my gaskets that came with the oil cooler R&R kit fit like a glove
I to use alittle oil on them to help hold in place if need be
Old Jul 30, 2011 | 06:09 PM
Sheryle's Avatar
Sheryle
FWIW...FYI, I did use new engine oil for lube. The gaskets seemed to fit okay when first installed.
Old Jul 30, 2011 | 07:21 PM
cheezit's Avatar
cheezit
do not use permatex on an o-ring. this is bad and can cause an o-ring to not seal. when putting together an oil cooler and having this type of issue I would suggest using a product like transgel wich is made to work with automotive grade o-rings. also vaseline will work.
Old Jul 31, 2011 | 08:27 PM
Sheryle's Avatar
Sheryle
Update
Cheezit! You da man! I used vaseline this morning to hold the seal in place. Worked like a charm. Thanks again for your help. Hopefully tomorrow I will be able to finish putting it all together.
fordmerc
Modular V10 (6.8l)
Dec 27, 2017 08:23 PM
'02strokerpilot
Feb 14, 2016 05:36 AM
10fords
Escape & Escape Hybrid
17
Apr 28, 2015 11:05 AM
jdw1
Dec 1, 2012 02:54 PM
Woodlums
Apr 24, 2006 08:23 PM
