Have a 95 F150 that the cruise went out 2 years ago (had recall done). Never figure out problem. My horn has just quit working. Air bag light comes on at start up then goes out. How do you check the clock spring? Thanks
I wish I had the link, but do search for user name "Nebacazar". He had a similar problem. I posted the link concerning the cruise control and horn problem. That's the best I can do for you now.
Edit: Nebachazar...I know how it sounds, just can't remember the spelling correctly.
Replace your clock spring, I just finished mine the other day, Not a bad job . Buy one from the parts guy on this forum and here is a link how to do it. Good luck
You have replaced the clock spring before? All the things , cruise control. horn not working and the airbag light blinks on and off is a plain indicator that your clock spring is defective, That is the test, Good luck.
steve
