What are your thoughts?
Old Dec 3, 2002 | 02:26 PM
billman's Avatar
billman
I will try to be brief. For the 1995 truck in the sig.
I took my truck to the local dealership (for warranty work) because it was losing about 2 quarts of coolant a week (~300 miles). I looked everywhere and could not find anything (cold or hot engine). They did their "pressure test" and said it was the gasket on the timing cover and replaced it. Got it home and was leaking a lot, all over the driveway (cold and hot), so I took it back (apparently they did not do another leak test to verify). They said it was now leaking from a hose from the intake manifold and flared up because they fixed the timing cover.
Does this make sense?
Old Dec 3, 2002 | 02:28 PM
slave2dafords's Avatar
slave2dafords
sounds to me like they would be replacing the hose for free they must have bent it around and loosened it up to the point of leaking and if it was leaking bad when you got home that means it was leaking there. throw a fit in the service dept. lol good luck
Old Dec 3, 2002 | 04:06 PM
edenroadmaster's Avatar
edenroadmaster
[updated:LAST EDITED ON 03-Dec-02 AT 05:07 PM (EST)]i agree with the slave. like the old addage says, the squeaky wheel gets the oil.
eden
Old Dec 3, 2002 | 04:20 PM
blue_mule's Avatar
blue_mule
