1978 - 1996 Big Bronco
p0500
Old Jul 29, 2011 | 09:40 PM
deadeyedevon's Avatar
deadeyedevon
p0500
Ok driving to the beach and the trans seemed to be acting up a bit. Then the O\D off light on the shifter starts blinking. Then my ultra gauge gos off with the code p0500 for the speed sensor.I cleared the code so the alarm would go off. After I cleared it the light stopped blinking but the trans still seems to be acting up.. .are there 1 or 2 sensors? One in the rear dif and one in the trans? How hard are they to swap out? Most importantly how much? Thanks guys
Old Aug 1, 2011 | 09:04 PM
deadeyedevon
bump
im going to replace the vss on the rear pumpkin, are there any other sensors on the actual tranny that i should lookinto swapping out while im at it?
Old Aug 2, 2011 | 05:53 AM
b4hntn's Avatar
b4hntn
Disconnect the battery while changing the VSS to clear codes. Then allow at least 20-40 minutes of varied driving to "relearn".
There are no other sensors outside the transmission however, the MLPS switch with resistors is a likely suspect if the VSS does not fix it.
Jimbod
2004 - 2008 F150
Apr 5, 2015 05:21 PM
wild4u11
1997 - 2003 F150
Jul 28, 2011 10:31 PM
jeffdoerr
Feb 15, 2010 08:50 AM
texasjack
Apr 2, 2009 07:52 PM
ildcr
Feb 19, 2007 10:12 AM
