Hello everyone , im trying to help my uncle with his bronco II , he have a problem with the manual transmision, he needs a plate that is located right under the stick shift, that keeps it steady, i have been trying to find
dealers or spare parts but i have been no lucky at all,
would somebody knows where i can find transmision parts or if someone have this part and is selling it ,
i will appreciate your support and time for reading this, the Bronco
is a 4x4 1987 stick shift manual transmision with a v6
Since those have not been made new for a long time, a wrecking yard would be your best source. Try to identify your transmission and check around at some different parts yards near you to see if anyone has what you need. Look around on your tranny case for an ID tag that is mounted to the side of the case or numbers stamped into it.
