HARD TO REMOVE COOLANT FILTER
Old Jul 29, 2011 | 10:39 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Arrow HARD TO REMOVE COOLANT FILTER
A while back there was some discussion about having a difficult time removing the coolant filters from the filter holder. Just had a thought and wonder if anyone has tried using a spritz of Fluid Film on the filter seal? Or would it hurt the seal in any way?
Will be time to replace mine in about a month so I've been thinking about it.
Old Jul 29, 2011 | 11:38 AM
smokersteve's Avatar
smokersteve
I grease the threads and o-ring before I put mine on.
Old Jul 29, 2011 | 11:48 AM
High Binder's Avatar
High Binder
I had the same problem so I ran a finger covered in engine oil around the mating surface of the rubber gasket and haven't had a problem since.
Old Jul 29, 2011 | 12:00 PM
Rusty Axlerod's Avatar
Rusty Axlerod
coolantfilterlube.com
$14.99 3.5oz bottle
Old Jul 29, 2011 | 03:00 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
'spensive engine oil!
Old Jul 29, 2011 | 03:40 PM
Rusty Axlerod
Just crossed my mind if there was such a thing many of us are **** enough to buy it.
Old Jul 29, 2011 | 04:24 PM
smokersteve
ha!!! no way, motor oil or bearing grease works just fine or even better than just fine....
Old Jul 29, 2011 | 04:46 PM
High Binder
$14.99 3.5oz bottle
Site said their prices were going up to $24.99 due to the high price of the plutonium used in the lube.
Old Jul 29, 2011 | 04:56 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
HAHAHAAHAHHAA -- OK guys.... back to the original question...has anyone tried using Fluid Film for this purpose?
Old Jul 29, 2011 | 05:59 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Good ol' motor oil here... you lube a coolant filter gasket just like you should be doing for a spin on oil filter.
Of course, this will now open up the debate if one should use synthetic or dino oil to lubrciate their coolant filter gasket!!!!
BTW, I use Rotella-Syn 5W-40 (because that is what I use in my truck)... but of course any oil will do!!!
I lube the gasket really well and try to leave it very wet... then screw the filter on by hand to ensure that I do not cross-thread the threads of the filter... then use my strap wrench to tighten. Have never had an issue in removing after X-many years and 150,000 miles of changing filters.
I have only ever used Baldwin filters and have just recently tried the WIX filter. Wonder if the "issues" people are having are with certain brand(s) of filters (unless they are forgetting to lube the gasket)???
Old Jul 29, 2011 | 06:48 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Well, since we know that the 6.0 will shear dino oil down very quickly, my vote is synthetic.
Since we shouldn't go here either, ATF should only go in the tranny.
What is the correct torque value of a Baldwin coolant filter?
I say "snug" foot pounds.
And no, I haven't used "Fluid Film"
There, I got back to the thread question.
Old Jul 29, 2011 | 06:52 PM
dchamberlain's Avatar
dchamberlain
I've actually always just wiped a little coolant on my gasket, since it's always readily available at the time, and I've never had any trouble getting them off. I think just about anything slightly slippery will work.
Old Jul 29, 2011 | 06:54 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Coolant didn't work on mine..... had to remove it and stick it in a big vise and use a strap wrench......
Old Jul 29, 2011 | 06:57 PM
Rusty Axlerod
Fluid film- a spray lube with silicone?
I used Motorcraft dino BTW. so that's what the coolant filter got. Thinking of T6 for oil change tomorrow hope it's compatable with my coolant filter gasket! <--grin
Last edited by Rusty Axlerod; Jul 29, 2011 at 07:02 PM. Reason: added stupid stuff
Old Aug 1, 2011 | 12:29 AM
olfordsnstone's Avatar
olfordsnstone
How's about ATF?
Sorry, couldn't resists...
