Sponsored by: Real Truck
Front axle ujoint
Old Jul 28, 2011 | 05:34 PM
03F350XLT's Avatar
03F350XLT
Front axle ujoint
03 f350 4x4
The dust seal on the passenger side is loose ( not my concern ) but reaching behind the wheel I noticed I can move the u joint up and down quite a bit with my hand. Makes a clink over bumps also. It's spins freely , no binding or seizing while spinning with hand with hubs unlocked. With hub lock no more clunk over bumps. Guess what I'm asking is thatvup and down play alright for now. Just the seal? Needle or spindle bearing? Any thoughts?
Old Jul 28, 2011 | 08:39 PM
Emustang04's Avatar
Emustang04
sounds like the u joint is bad, I beleive if anything else was bad it would move in other areas. locking hubs usually use a sliding collar that locks the front half-shafts to the hub. so if it goes away then im guessing its just the u joint thats spent.
Old Jul 29, 2011 | 03:13 AM
99f350sd's Avatar
99f350sd
needle bearing bad? Pull it apart!!!
Old Jul 31, 2011 | 07:48 PM
03F350XLT's Avatar
03F350XLT
If just the needle bearing was gone would that create the up and down play in the u joint / axle shaft end? I plan on doing break work all around so when I do I'll pull the bearing assembally and replace the needle bearing. If I have to pull the axle shaft/ u joint I'll be replacing the seals as well. There's is no 4x4 in use till winter. Should I rush into this repair?
Old Jul 31, 2011 | 08:57 PM
99f350sd's Avatar
99f350sd
If the needle is gone the shaft may be also...Sooner rather than later in my book..
Dick
Old Jul 31, 2011 | 09:11 PM
03F350XLT's Avatar
03F350XLT
I hear ya. I'd hate to pull the wheel bearing and replace the needle bearing , reassemble only to find there is still the play in the u joint. But if I end up having to do the outer axle shaft I'll be doing the u joint anyways I guess. Gunna have to get my hands dirty I guess
Old Jul 31, 2011 | 09:15 PM
99f350sd's Avatar
99f350sd
The ujoint does have quite a bit of play in there normally..More than you would think but it works fine. You can save the big seal if you can pry out the shaft from behind with big pry bars.
DontUluvFod
Oct 9, 2014 06:28 PM
ticketed2much
Jul 19, 2012 11:12 PM
shawnegg
Jul 27, 2011 02:03 PM
preppypyro
13
Jan 25, 2011 11:17 AM
lalevant
Jun 12, 2009 11:47 PM
