sd and osb
Old Jul 28, 2011 | 08:09 AM
brokeisnojoke's Avatar
brokeisnojoke
sd and osb
Ok so my buddy has a 2000 f350 7.3. Hpop went out and he cracked a piston. I want to know wat all can be swapped. I already have his ipr in my truck. Can the computer, and idm be swapped? He can't afford another 7.3 so he's dropping a 12 valve in it I would like to buy the whole motor with out the hpop. He bought a brand new one and discovered the piston after he put it in. 8 good injectors aren't going with the motor. He had those sold already
Old Jul 28, 2011 | 08:49 AM
superduty4x4's Avatar
superduty4x4
IDM yes, computer no. Since the HPOP is "bad" and he sold the injectors already, there's really nothing else that would be an upgrade for you off his motor.
Old Jul 28, 2011 | 08:54 AM
brokeisnojoke
He has a brand new hpop
Old Jul 28, 2011 | 10:07 AM
superduty4x4
Buy the HPOP and IDM off him and don't worry about the rest. Grab the intercooler and piping if he's not going to use it on his Cummins.
Old Jul 28, 2011 | 10:31 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
And what about some sensors?
Old Jul 28, 2011 | 07:03 PM
F350-6's Avatar
F350-6
And maybe everything needed for electric fuel. Possibly the intake plenums, turbo & up pipes if you get the intercooler. That would give you the option of more affordable bellowed up pipes or different turbo upgrades down the road. If he's willing to let the PCM go cheap, grab it and send it off to your favorite tuner to get it flashed to your truck with a tune on it.
Old Jul 29, 2011 | 08:12 AM
brokeisnojoke
Im sure he will let the pcm go for around $75 or $100. How much would it cost to get it flashed? I tried to get the whole truck but he is dead set on that 12you valve. The truck is a dually with no scratches or dents. And has about 120k on it.
Old Jul 29, 2011 | 09:40 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
You didn't say what year your truck is but I think if it is 95 and older the HPOP needs to be the type with the drain back? That is why a lot of guys send in their HPOP to be modified I thought. Maybe it is just cheaper, not sure.
Old Jul 30, 2011 | 08:33 AM
brokeisnojoke
My truck is a 95 motor is a 96
Old Jul 30, 2011 | 10:23 AM
CSIPSD's Avatar
CSIPSD
The PCM is of a different family. It can not simply be reflashed.
It will not work.
Old Aug 1, 2011 | 10:44 AM
superduty4x4
The pump would be the only useful part. No sense in buying the turbo parts to "upgrade" to an SD turbo IMO.
akaFrankCastle
Jun 16, 2012 08:58 AM
indyF-350psd
Ford Truck Parts for Sale
May 13, 2011 08:55 PM
kkalmer
Oct 14, 2008 03:33 AM
Chris Iverson
May 22, 2004 01:05 PM
