A/C Compressor Clutch
Old Mar 31, 2003 | 05:07 PM
lostbuckaroo's Avatar
lostbuckaroo
It's getting warm here is California and I decided to excercise the A/C to make sure everything is in working order. When turning the switch to a/c and a/c max the air doesn't cool at all. I opened the hood and noticed that the a/c clutch doesn't activate. I took that plug off on the front of the compressor just behind the pully, put a test light on it and I'm getting no juice at all. I've checked all the fuses and everything is ok there. Any other ideas? Am I checking the wrong plug? Could it be something else? It worked great last summer.
I want to avoid taking it in if I can.
Thanks
Old Mar 31, 2003 | 05:32 PM
84deisel's Avatar
84deisel
here sometimes
a low pressure cut off switch is used on that system. The switch is located on the reciever/drier. It is possible the system may be low on refrigerant
Old Mar 31, 2003 | 05:40 PM
lostbuckaroo
Do you know of a good place to get A/C refrigerant kit? The must come with a guage.
Old Mar 31, 2003 | 05:46 PM
84deisel's Avatar
84deisel
here sometimes
Most major auto part stores have them . But in most states you are required to be a certfied in mobile a/c repair . Some quick lubes usally run specials that may actually be cheaper than buying the equipment and refrigerant.
Old Mar 31, 2003 | 05:49 PM
lostbuckaroo
Thanks for your Help.
Old Mar 31, 2003 | 06:16 PM
I am Danll's Avatar
I am Danll
A Fair set of 134A gauges go for about 90 to 100 bucks check out a local refrigeration supply shop. DONT shop for A/C equipment at your favrite auto parts store. 12 oz cans od 134a are about 3.50 to 4.00 dollars i dont know if you have to be EPA 609 Cert to by 134A which is what your truck has. but the law were supose to change and if it isnt that way yet it will be soon. most ahops will do an a/c tune up and it will include x amount of freon for less than what you can get the equipment for.
Old Apr 5, 2003 | 12:28 AM
steve83's Avatar
steve83
Currently, the sale of R-134a is unregulated.
TommiFIN
13
Aug 8, 2013 09:49 AM
SleeprLegend
13
Apr 22, 2011 08:43 PM
MSG
1983 - 2012 Ranger & B-Series
28
Dec 22, 2006 03:49 AM
PowerstrokeDude
Sep 21, 2006 10:28 PM
marragtop
May 8, 2006 05:25 AM
