Sponsored by: Real Truck
Drop Hitch
Old Jul 26, 2011 | 04:49 PM
GeneLaw1's Avatar
GeneLaw1
Drop Hitch
Hello,
I was in the market for a hitch and tow ball, and I started to wonder how much of a drop I need to get...is there any easy way to tell? I've seen 2 - 5 1/4 inch drops in the auto stores, so just wondering....I can link to a picture of the truck if that would help out....2006 F250 Lariat
Cheers!
Old Jul 26, 2011 | 04:54 PM
barthel's Avatar
barthel
Level the trailer, then measure from the ground to the top of the ball coupler. Then, again on a level surface, measure from the ground to the center of the receiver. The difference is your drop (within a half inch or so).
kd0axs's Avatar
kd0axs
Depends on the trailer. I have a few different hitch inserts of different heights for different trailers.
Old Jul 26, 2011 | 05:09 PM
maverick22's Avatar
maverick22
It's going to depend on the height of your truck and trailer(s). On my stock 2005 (w/ 265/70/17 tires and overload springs) a 2 1/2" drop is about right for most of my trailers, a 3" might be better but I couldn't find one when i was looking. 4" was too low. Your milage may vary.
The correct way is to measure like mentioned above, but you might end up needing a different drop for each trailer. I don't haul anything very heavy off the drop so I wasn't too concerned if mine aren't exactly level, but they're not far off either using the 2 1/2" drop.
Old Jul 26, 2011 | 05:12 PM
Trophy_23's Avatar
Trophy_23
Depends on the trailer and whether your truck is stock height. I run a 4" drop with 2-5/16in ball and a 6" drop with a 2" ball for a smaller trailer.
Old Jul 26, 2011 | 05:42 PM
barthel's Avatar
barthel
Definitely depends on the trailer, which is why you have to measure each one. I have 3 different trailers that I pull, I have a different ball hitch for each one.
Old Jul 26, 2011 | 07:20 PM
Pili's Avatar
Pili
would make more sense to get an adjustable drop receiver and a 3 ball setup if you tow a lot of different trailers?
Old Jul 26, 2011 | 07:25 PM
kd0axs's Avatar
kd0axs
Maybe, but for the price of one of those you can buy several regular hitch inserts.
Trophy_23's Avatar
Trophy_23
Its a good idea long as you can lock it. Hitches seem to go missing if not locked. For me I only needed the 2 so I bought seperate ones, but the adjustable ones are nice!
Old Jul 26, 2011 | 07:33 PM
dkf's Avatar
dkf
Same here.
Depending on how the load weight I even change drops for the same trailer to correct for rear end sag.
And have less slop and something that looks decent.
Old Jul 26, 2011 | 07:35 PM
Pili's Avatar
Pili
Ever since i had a 2.5 drop hitch stolen in a parking lot i keep the hitch locked in the truck unless its hooked to a trailer. As for the expense of the adjustable drops you get what you pay for i've seen them as low as 50 bucks and as expensive as 200
Old Jul 27, 2011 | 09:05 AM
Trucky2's Avatar
Trucky2
The "standard" is 17 inches from the ground to the top of the ball. That being said I have two trailers that require a 15" ground to top of ball height and one that needs 18". Whatever your trailer requires I would add 1" to allow for the sag you'll get from adding 300-500lbs of tongue weight.
Old Jul 27, 2011 | 09:09 AM
GeneLaw1's Avatar
GeneLaw1
Ok this is good information here...it would be mainly for towing a car, so I am guessing adding that inch would help with that sag I would get...
Old Jul 28, 2011 | 08:16 AM
grec-o-face's Avatar
grec-o-face
Same here, I have two different inserts. One is about 5-1/4 or so. But the one I use the most is an 8" drop with a 2-5/16 ball. I pull a car/machine trailer that's fairly low to the ground (for easier loading) - so the 8" is perfect with my stock suspension and 285/75/16's.
I've been looking at the adjustable set-ups too, but I think I'd rather put the money towards a pintle hook instead. I hate borrowing stuff like that.
Old Jul 28, 2011 | 08:29 AM
Trucky2's Avatar
Trucky2
Depending on what you will be towing, make sure to look at the rated capacity of the drop hitch and the ball itself. I think the Class III hitches run up to about 5,000 - 6,000 GTW and are usually hollow. For a few dollars more you can get a Class IV or V hitch that is solid forged with GTWs from 6k on up over 10k. Match the right ball and you should never have to worry about the load. I found Northern Tool and Tractor Supply to both have a fairly decent bunch to choose from. I think I just spent about $60 for a 2 1/2" drop Class IV with a 2" ball, both rated at 7,500lbs to pull a new boat.
