1978 - 1996 Big Bronco
my 89 bronco
Old Mar 31, 2003 | 02:34 PM
89 Ford Bronco Owner's Avatar
my 89 bronco
sorry if i sound like another one of those stupid kids
but i want to know if my bronco has any kinda limited slip or anything on it
or if that was an option back then and it may or may not
thanx for your time
o and it has a flowmaster but it also has a cat
so would it make a big dif if i cut the cat off and just put a pipe in its place??
Old Mar 31, 2003 | 02:53 PM
mrwizard's Avatar
mrwizard
my 89 bronco
If you still have the sticker on the inside of the driver's door jamb, there will be a code for the axle that will tell you. If the code is 2 numbers, i.e. 19, then it is not L/S, if it is 1 letter and 1 number, i.e. H9 then it is L/S. This is only for the rear axle though. Front L/S is pretty rare.
Before you remove the catalytic converter, do you have any kind of emission testing in your area? If you do, you should probably keep it, especially if they do any visual checks at the same time. If performance is your idea, replace the stock cat with a good, high-flow model. Still emissions legal, and better performance than stock.
Old Mar 31, 2003 | 06:15 PM
greystreak92's Avatar
greystreak92
my 89 bronco
If the door sticker is goen or obscured for whatever reason, there should be a tag on the rear differential cover with the gear ratio stamped in it. it will either have 3 55 or 3L55. Unless you have a different gear ratio from the factory. Either way the second digit determines whether you have an LS diff. or not. 3L55 has the LS 3 55 does not.
Old Mar 31, 2003 | 08:28 PM
my 89 bronco
thanx alot guys
o and i live in florida so no need for emishions
Jason Lambert
Feb 26, 2015 01:56 PM
junkdrmr
Nov 14, 2010 10:47 PM
Schlump
Oct 26, 2003 04:38 PM
brocko
Bronco II
19
Aug 13, 2003 10:56 AM
blue00
Aug 15, 2000 01:24 AM
